V6 MPFI to V8 L98
Old Mar 9, 2005 | 03:01 PM
firefrombelow's Avatar
V6 MPFI to V8 L98
Am I gonna need a new dash/guage cluster? I read that the Tach will be off about 20%, but the other guages will work fine. I have a 91, so will any 91-92 L98 Cluster Work? Or can I use a 5.0 TPI cluster? Are they the same?
Thanks.
Old Mar 9, 2005 | 03:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It is only the tach that is different. You just need a V8-calibrated tach, doesn't matter whether LO3, LB9, or L98.
Old Mar 9, 2005 | 03:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
just take note if any gauge locations were changed, like from the 85 dash to the 88 for Firebirds.
Old Mar 11, 2005 | 02:42 PM
Thanks for the responses!
So, does the cluster have to be a 91-92 or any year?
Old Mar 11, 2005 | 11:07 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
Depends. In 1990 the Camaro switched over to the electronic dash. From 1982 to 1989 they were belt driven.
Firebird's had electronic dashes since 1986.
I see you have a 1991 car. So, you can use any v8 cluster from 1990 to 1992.
C409
May 1, 2015 09:36 AM
SweetRide45
Nov 9, 2003 12:08 AM
widow_maker89
Jul 22, 2002 01:39 PM
jjstealth2000
Dec 16, 2000 04:22 PM
jjstealth2000
Dec 4, 2000 08:26 PM
