ls1 going in iroc-z
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ls1 going in iroc-z
figured ive done the dash/console swap, why stop?
i got a smoking deal on a 6.0L motor. gonna throw a cam in it and roll out.
anyone put a 6.0 in before? seems all have been 5.7's
wish me luck.
be a few months while i locate the rest of the goodies i need, but the headache starts now.
wish me luck.
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
Good luck with the swap...theres always fun little problems that come up, just gotta plan ahead. If ya need any help there are plenty of us ThirdGen LS1 swappers that have run into about every problem you could think of.
BTW how difficult was that dash swap?? Ive always wanted to get rid of the "roof" in my camaro.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
dash swap is a must. if you can swap a motor, you can do the dash. i dont have a/c, so it made it a tad more easy.
ive searched and it seems the motor mount kit also comes with a trans crossmember as well.
i already have a spohn torque arm for a TH350, and a very expensive driveshaft im not replacing.
is there a mount that will replace the stock v8 mount exactly where it is now, or does the motor have to be moved forward or back for clearance reasons?
thanks
thanks
Car: 1991 camaro Z28
The 6.0 is going to basicly be the same as a ls1 swap, your just going to need to switch the oil pan, windage tray, and pick up from a ls1. The truck pan hangs down to low and will be a clearance issue, as for the mounts you can get them from spohn, hawks, or f-bodymotorsports. They will mount bsicly in the same place as you stock ones are.
Justin
Justin
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by TattooedScumbag
Ive been out of the loop for a while....a 6.0 LS1 comes in a truck? whats the difference in the one out of corvettes?
yea the truck 6.0(lq4/lq9), are basicly the same as the vette motor(ls1/6), but the truck is iron and slightly bigger(6.0 vs. 5.7). Alot of guys switch to the iron block when there ls1 goes becuase they can stroke it out to a 402 and they like the added strength. All the parts between them are basicly interchangable(except for a few alternator).
Justin
Justin
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
It also has a more low end cam. Not a performance cam. Not sure on valve train and rotating assembly. Im about to go with a 6.0 out of a silverado myself.
Car: '90 RS
Engine: 377 LSX
Do they have the same intake or is it a tbi setup?
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i have a tubular k member. ive got a huge moroso oil pan on there now and it clears. ill have to toss the motor in and see if she clears. thanks for the heads up.
all these posts are the exact reason i went with the 6.0. im going to eventually stroke it to 440ci and have a nasty set of ported heads.
these combos are pretty drivable and see 525-575 wheel power depending on what cam you run and what tranny you have.
new technology is great.
this thing stock with a cam is prolly gonna make 400whp.
