Just got my LS1
Old Mar 23, 2005 | 08:21 AM
fattdaddy's Avatar
Car: 1992 Rs
Just got my LS1
I just got a LS1 and 4l60e for my 92 RS, the motor has 88,000 miles and came out of an 99 TA!
Believe it or not this TA still runs and drives!!!
Old Mar 23, 2005 | 10:14 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome aboard!
Sounds like you have a nice project on your hands. Keep us posted on your swap results.
Old Mar 23, 2005 | 10:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
schweet... good luck on the swap!
if you have any questions, just post them up.
btw, are you planning on running the stock wiring harness?
what are your plans for the fuel system?
Old Mar 25, 2005 | 11:43 AM
fattdaddy's Avatar
Car: 1992 Rs
Stock wiring harnes yes and the fuels system out of the car that the motor and tranny are coming out of!
can I just put the LS1 in the car without the AC and shorter belt?
And will the LS1 radiator go in the the third gen with using the stuff from the third gen!
Old Mar 25, 2005 | 12:32 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You should be able to find your answer with a few searches here on TGO. Most guys re-use their stock radiator.
Old Mar 26, 2005 | 01:14 PM
CamaroCain's Avatar
Car: 88 Camaro
The LS1 radiator will not fit with out some work and some custom brackets to hold it in. The a/c compressor is on a different belt off of the crank all together, so just removed the compressor and the compressor belt and you use the stock other belt and are good to go.
Clint
Old Mar 26, 2005 | 03:12 PM
fattdaddy's Avatar
Car: 1992 Rs
Clint
Yea I'm going to try to fab something too make it work the other radiator I have is from a V6! thanks for the info!
Old Mar 26, 2005 | 05:47 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
It'll be nice to lay down 350 HP and still get 20 MPG!!!
I'm jealous...... Congrats!!
Old Mar 27, 2005 | 08:38 PM
fattdaddy's Avatar
Car: 1992 Rs
will the v6 radiator work just as well or should I get one out of a v8!
Old Apr 26, 2005 | 06:49 PM
fattdaddy's Avatar
Car: 1992 Rs
THE LS1 IS LOOSE!!
Here is a pic of the stock heads going in on a core for some stage III's
And here is one of the the 4l60e that going with it!
Old Apr 26, 2005 | 08:02 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
91-92 thirdgens came with the v8 radiator. Im using my 91 v6's original radiator with my lt1.
Old Apr 26, 2005 | 09:14 PM
fattdaddy's Avatar
Car: 1992 Rs
Cool, I would still like to rig up the LS1 radiator before I settle with the third gens!
Old Apr 27, 2005 | 09:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
ls1 radiator fits with a little tweeking.
its angled a little more, but its also angled more in the 4thgen.
Old Apr 27, 2005 | 08:22 PM
fattdaddy's Avatar
Car: 1992 Rs
what radiator shroud are you using with the LS1 radiator!
Old Apr 28, 2005 | 04:11 AM
CtRw's Avatar
Car: 1983 Camaro Z-28
I used the LS1 radiator. Just fabbed up a peice of sheet metal that bolted into stock holes and over and down. I'll try to get a pic.
Old Jun 25, 2005 | 11:24 PM
fattdaddy's Avatar
Car: 1992 Rs
Here is some of the body about a month away from paint! floor board will be all new metal and it will be painted with POR 15!
All emblems and corner lights are shaved
Shaved Door handles and locks
Sun Roof no more
Old Jun 25, 2005 | 11:26 PM
fattdaddy's Avatar
Car: 1992 Rs
The roof is in and starting to come together
Soon the whole inside will be painted with Rust Bullet!
fattdaddy's Avatar
Car: 1992 Rs
Here is the pics after the first coat!
Old Jun 26, 2005 | 08:44 AM
RaGe's Avatar
Car: 1990 Firebird Formula
I'd like to hear more about rust bullet as I'm planning on coating my whole chasis with it.
Did you brush on or spary on? Is the silver stuff the rust bullet or does it dry more white?
Nice setup by the way...and you are pretty good at what you do as I would have been scared of the sunroof and less so the floor.
Old Jun 26, 2005 | 07:48 PM
fattdaddy's Avatar
Car: 1992 Rs
It comes out silver and I think thats the only color I sprayed I do paint and body so It was easier that way for me cleans up with laquer thinner For more info on rust bullet go to http://rustbullet.com/?trackcode=bizcom
Old Jun 26, 2005 | 11:40 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
cool, rustbullet............and my gov't card w/gsa.........
let me know if' you're really not gonna use the 92 radiator, as I cain use it for the 305 .
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
