car runs for 5 sec ten shuts down
Old Apr 4, 2005 | 03:35 PM
ssean92's Avatar
Car: sold
I just got done with the lt1 swap and know it only will stay running for 5 sec. then shuts down i installed the bypass for the vats and it does the same thing. i talked to the guy that did the harness and he said to just hook up the vats wire to the existing vats wire i did that and it did the same thing. i turn the key and the fuel pump kicks on the cuts off after 5 secs. turn the key to start and it runs for 5 sec then shuts off????????? shouldnt the pump run all the time while in run? I am lost on this one can you help me out on this one. its hard. i thought that the vats bypass would have worked. well it is because if i disconect it it dont start at all. the wire i have it hooke to is the black and yellow on by the drivers kick panel it is hooked to a relay of some kind. that what my wiring shows the the passkey signal comes from. is there some were else this vats need to go?
Old Apr 4, 2005 | 03:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like all that's hooked up is the timed "start" fuel pump relay.
You also need a circuit that goes through the oil pressure switch.
Old Apr 4, 2005 | 05:09 PM
ssean92's Avatar
Car: sold
well i figured it out i had the vats hooked up wrong i just hooked it up to the lt1 computer and it works runs as it should. know i need to figure out the alt why its not charging. its coming slowly.
kyleb24
Aug 15, 2015 08:24 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Kaweh
Aug 9, 2015 02:54 PM
Fronzizzle
Aug 9, 2015 01:15 PM
