serpentine belt problems
Old Apr 5, 2005 | 04:36 PM
ladys_man143's Avatar
Car: 88 Camaro RS
Engine: 2.8 L
Transmission: 5 speed
hey, i need some help.
i just dropped a 2.8 out of an 85 firebird into my 88 camaro. i go to put the belt on and even with the tensioner lifted all the way, the belt still wont fit, any ideas? i can try to put a pic up if that will help.
Old Apr 5, 2005 | 05:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Are you routing the belt on in the right direction? Are you sure you have the correct length belt? Is your tensioner shot?
Old Apr 6, 2005 | 08:11 PM
Car: 88 Camaro RS
Engine: 2.8 L
i switched everything off the 88 motor and put it one the 85. the 85 had multiple belts, with a locked up air pump, so i decided to switch everything over to the single belt I had on the 88. i was trying to use the same belt off the 88, but its like 2-3 inches short. The belt is routed in the correct way, unless it wasn't before, or something was installed wrong before. either way, as long as everything is secured, and nothing is in the way, i can just buy a longer belt, right? thanx
Old Apr 7, 2005 | 09:30 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
Don't forget that the water pump spins reverse on a serp system.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
