305 tbi to 350 tbi
Old Apr 6, 2005 | 12:34 AM
tranceemotionz's Avatar
Car: 1991 Chevrolet Camaro Z28
Engine: 5.7L TPI L98
Axle/Gears: 3.23 posi/limited slip
305 tbi to 350 tbi
i bought my 92' rs in 2001, the previous owner had installed a jet performance chip and an accel electronic super coil. since then ive made a few upgrades such as, k & n air filter, high flow cat, flowmaster exhaust, richmond 3.73 ring and pinion, and for the suspension i have kyb gr2 shocks and struts, and polyerethane bushings from energy suspension. future upgrades include a posi traction unit, edelbrock ti - tech headers, and an aluminum drive shaft. when it comes to the engine im a little puzzled. i know that whatever i do to the 305 i can get more power out of a 350. so i am thinking about having a local machine shop build a 350 tbi roller motor. my question is to put this motor in, what mods are needed? Do i have to change the the computer, or the chip.... if anyone can help id greatly appreciate it...
thx
Old Apr 6, 2005 | 07:08 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
My friend did just this with TPI. You will need a chip and injectors for a 350. Possibly a larger throttle body?
Old Apr 6, 2005 | 08:45 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will need 350 injectors, knock sensor, ESC module and a new chip. It is also a good idea to replace the fuel pump with either a high flow unit or a TPI one. The stock 305 pump is junk and can't feed any type of motor that has power. The mods on the 350 will deterime TBI unit and prom (chip)selection. You you just use a stock LO5 caprice 350 TBI as your motor you can get away with the chip from that car. If you add heads or even just a cam you will need to burn a new chip. This cannot be done through mail order so you will have to have someone do it for you or learn to do it yourself. It isn't that hard so don't get disscouraged. Chip work is the key to any extensivly modded TBI system. Without it your car will be slow and have horrendous road manors.
Old Apr 6, 2005 | 11:11 AM
hey thanks a lot yall, i really appreciate it. the only other question i have is where to go to get a chip? i have no idea how to burn one so i dont know.. but once again thanks a million
Old Apr 6, 2005 | 02:25 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Take a look at the DIY PROM boards as well as the stickies in the TBI forum. They will get you started on chip burning. It isn't that hard so get ready to learn If you get the motor out of a carpice than just nab the chip while you are in there.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
