350 T/a
Old Apr 6, 2005 | 08:06 PM
Blue Vortec's Avatar
Car: 85 T/A, 77 Vette
Transmission: G Force 5 Speed
350 T/a
I am putting a computer carbed 350 with Vortec heads into an 85 T/A that has an L-69. Do I use the same harmonic ballancer that came with the 305 with the new 350 short block? Also what 4 barrel intake manifold for vortec heads will fit under the stock T/A hood?
Old Apr 6, 2005 | 10:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you are using the same belt system as the HO engine did, then you should use the 305 balancer.
Old Apr 7, 2005 | 09:07 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 350 T/a
Originally posted by Blue Vortec
... what 4 barrel intake manifold for vortec heads will fit under the stock T/A hood?
Without a doubt, the Performer will. Not sure about the others.
Old Apr 7, 2005 | 07:35 PM
Air_Adam's Avatar
Which "stock TA hood" is it btw?
Old Apr 9, 2005 | 01:40 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
So if you go with an aftermarket balancer for the 305-350 swap, you can't use the stock belt system?
Old Apr 9, 2005 | 04:00 PM
Air_Adam's Avatar
AFAIK, you can, but the HO's belt system is designed to use a thinner-that-usual balancer, so the stock crank pulley is 'modified' to work with that balacer.
Basically, if you go with an aftermarket balancer, you can either get a thin one, like the HO used, or get a normal one and a crank pulley to match.
I *think* this is how it works, but I might not be 100% correct. I'd wait for someone else to agree/disagree with me before you use what I said.
Old Apr 10, 2005 | 07:36 PM
84 t/a 5.0's Avatar
Do you happen to know what size the stock one is? I may just end up getting one from napa for my swap.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
88rscamar0
Sep 23, 2015 09:08 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
scotrans am
Sep 5, 2015 04:26 AM
Formula_88AE
Sep 3, 2015 01:47 PM
