Trying to finish swap, ran into question.
Old Apr 7, 2005 | 11:02 AM
weigesco's Avatar
Car: 89 RS Convertible
Engine: 350 Carbed, No Computer
I have this on the electronic board also but am not hearing anything. So if anybody here can help, I need it bad. I am trying to finish my motor swap and hit a snag. I am switching from a 305 TBI to a carbed 350. In some of the posts on here it says to connect the new HEI dist to a red/pink wire and a black wire. Others say it should be a red/pink wire and a white wire. The old coil had a red/pink wire and a white wire. It also had 2 wires that plugged into the old dist. The old dist had 4 wires coming into it, red/pink, black w/red stripe, purple w/white stripe, tan. What should I use? I looked through my Hanes manual without any luck as to which to use. Thanks.
Old Apr 7, 2005 | 11:28 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
mine is an 86. pink wire was +12 to hei and white was for tach. you can check pink wire it should have +12 to ground when key is on.
Old Apr 7, 2005 | 03:13 PM
weigesco's Avatar
Thanks. Do you remember if you used the white wire that ran to the external coil or the white wire that ran from the wiring harness to the distributor?
Old Apr 7, 2005 | 03:25 PM
SPIKE's Avatar
Car: 86 CAMARO
white wire that goes from harness that comes out under steering wheel.
Old Apr 7, 2005 | 05:10 PM
weigesco's Avatar
Thanks a bunch. Hopefully I will get it fired up tonite.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Cleotiz
Jan 6, 2018 08:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Bryan F
Aug 18, 2015 02:28 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
