454 6speed question
Old Apr 13, 2005 | 02:09 PM
FaSStcars's Avatar
Car: 1988 RS Camaro 1992 Z28 (crispy)
Transmission: 5 spd
454 6speed question
My 92 RS has a 6 speed already and I also have a 454 I want to install later this summer. My question is. I have a new flywheel for the 454 but it is bigger that the 6spd flywheel. Do I get a different flywheel or do they make a pressure plate that works with the 6 speed and 454? Thanks
Old Apr 13, 2005 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You will need a different flywheel. THe only one I know of off the top of my head is from Centerforce; but it's possible that there are others.
There is no need to change the pressure plate, if you get the right flywheel.
Old Apr 14, 2005 | 02:26 PM
FaSStcars's Avatar
Transmission: 5 spd
So would you ask for a centerforce flywheel for a 454 6speed combo like from summit or jegs? Or does that flywheel have another aplication?
Old Apr 14, 2005 | 04:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It lists for the SB 400. You can look it up on Centerforce's site. Get a good grip on the arms of your chair before you look up the price.
Old Apr 16, 2005 | 08:33 PM
FaSStcars's Avatar
Transmission: 5 spd
Just curious if you have done the swap already do you have the part number sitting around? I'm holding on so you can give me the price. I new stock 454 flywheel I just picked up was about $43. Is it higher than that :-). If the flywheel has a stock application I may be able to pick it up from the parts store and save a few bucks.
Old Apr 16, 2005 | 09:09 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
There is no stock app for it, that's why it's so expensive. I checked into it alittle bit when I first got my sb400 and it was around $375 it could be different now.
Old Apr 25, 2005 | 09:56 PM
FaSStcars's Avatar
Transmission: 5 spd
Hey thanks for the help. 375 vs 43 is a little bit of a difference :-)
Old May 5, 2005 | 03:36 PM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Transmission: Turbo 400
Axle/Gears: Moser 9 inch/4.56 gears
A smallblock 400 and a 454 take different flywheels. They are both externally balanced; however, the counterweights are different.
Old May 5, 2005 | 05:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yep; but if you have the one, you're about ¾ of the way from a 350 or 396 flywheel, to a 400 or 454 one.
Old May 5, 2005 | 05:13 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Just a thought , could you use one of those balance plates that bolt on with the flywheel? I remember when I did a 406 for my 85Z and I ended up using a balance plate for the 400 with the 305 flywheel, it worked out fine, no vibs and the plare was only 22.00 (I did it this way because no one made a 12 3/4 400 flexplate) I know I have seen them for 454`s so it may be a cheap way out if you could find a neutral balance wheel that has the right diameter for the T56 that will bolt up to the 454
Old May 6, 2005 | 08:01 AM
ckeene502's Avatar
now how about mating a t5 behind a 454? i have tried calling mcleod but no one ever answers the phone there.
Old May 6, 2005 | 08:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
83-85 T-5 flywheel, have it custom "unbalanced" to match the 454.
Have lots of T-5s on hand. I doubt a T-5 would make it all the way to the grocery store before getting shredded.
Just because something can be done, doesn't mean it's a good idea to do it.
Old May 6, 2005 | 02:51 PM
FaSStcars's Avatar
Transmission: 5 spd
The 454 is externally balanced. The flywheel I have is for a 454 but since the flywheel is bigger than the LT1's the pressure plate won't reach the holes to bolt up. I'm wondering if I can't re-drill the 454 flywheel to accomadate the LT1 clutch set up. I mean really all 's that would be important is for it to be centered. the flywheel will balance the motor.
Old May 6, 2005 | 04:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I don't think so.
AFAIK the 14" flywheel won't fit inside the LT1 bell housing.
MustangBeater20
Oct 29, 2022 09:20 PM
87iroctheo
Dec 4, 2016 11:47 AM
redmaroz
Aug 16, 2015 11:40 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
