Short tail shaft or long
Putting an Chevy 400 small block (carbed) , into a 86 Camaro. (Was V6) Want to put an 700r4 behind it. Need to know do I need short tail shaft or long. Also what kind radiator works best.
Having mechanic do it.
Any help or advice welcome
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
AFAIK, all 700R4's have the same length tailshafts, except on Corvettes. You'll need to use the tailshaft housing from a thirdgen to use the stock torque arm setup.
