305 tpi to 350 carb
Old Apr 22, 2005 | 12:33 AM
boa34b's Avatar
Car: 1986 z28 and 1989 RS v6
Engine: 350 carb and 2.8 MPFI
305 tpi to 350 carb
I am replacing my 305 tpi with a crate 350 carb and have a couple of questions.
I am wondering if I can use the fuel pump in the tank or should I get a mechanical one?
Also, will I need the return line, the fuel canister and the diaphram that was used with the tpi?
Sorry if these are dumb questions but I have to learn somehow.
Kind of got over my head with this car.
Old Apr 22, 2005 | 07:40 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
You can use your stock pump, you need a 3 way pressure regulator, you keep your return line. Some people remove their evap canister, but I'd just leave it alone.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
