89rsv6 to 87 tpi
Old Apr 25, 2005 | 09:42 PM
cody mcguire's Avatar
Car: 89 rs camaro
Engine: tpi 355
Transmission: th350 manual valve body
89rsv6 to 87 tpi
wassup f body freaks, i pulled the 350 tp out of an 87 formula firebird i was expecting to drop it right on the camaro after i removed the engine compartment harness, thinking i could plug the bulkhead from the formula into the camaro. im thinking i need to change the under dash harness..........or am i dreaming???? does anybody know if the formula bulkhead and iroc are the same? do i have to tear into the dash, besides the tachometer?
Old Apr 25, 2005 | 10:32 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
If this is a V6 to V8 conversion check out this thread. ---> https://www.thirdgen.org/techbb2/sho...hreadid=229665
Old Apr 26, 2005 | 09:41 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I can't say with any certainty, personally. You should have gotten everything up to the ECM from the '87, including the harness between the ECM and bulkhead. However, with the instrument cluster differences between 'Birds & Camaros, I don't know whether you'll have compatibility issues. Certainly you should try to get a V8 tach for a Camaro of your year/style. I'm not familiar enough with the digital instrumentation of the 'Birds to say what issues may come up.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
