camshaft help.
camshaft help.
Hi guys, I am kind of new at this, If you could help me it would be great.
I just purchased a 1971 350 4 bolt main block, bored .030 0ver.
it has ported and polished 601 casting heads from a 305.
the previous owner sold the block becuase he got ahold of a 454.
here is my questions.
I just rebuilt the engine 10 k ago. I used the same cam, it no bad wear patterns. the old owner said it was a comps cam with .0500
lift, I dont know the duration, but the power of this cam comes on around 2800 rpms and pulls to seven. I think it is a circle track cam.
the manifold on it is a victor jr. I have a street avenger 670 on it right now.
my firebird is a 87, with a 3.23 rear end and the stock 5 speed.
the car is gutless below 3 k above that it is a rocket. the car has a very defined lope.
I believe my compression is at 11;1 because I get 235 psi per cylinder.
I need help picking a better cam and manifold.
All I want is for it to sound good have decent power and be enjoyable to me.
any help would be great...
thatnks
tarrent
thatnks
tarrent
Transmission: 4L80E/4L80E
Welcome aboard.
More gear would help keep the time below 3000 RPMs at a minimum, but you're probably right in thinking it's time to change cam & intake.
A Comp XE268 or XE274 would lower the RPM band. A Performer RPM or Stealth dual-plane intake would come in sooner and pull as long as the cam would.
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
