specs
Old May 19, 2005 | 08:15 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
specs
com 270 h-10 cam
stock 79 350
416 heads
600 cfm edelbrock
Holley street dominator 300-38
.039 head gasket
I calculated my compression guessing at -4cc for the pistons and stock deck height of .015 and it came to 10.31:1. Would that be ok with 93 octane or will I blow holes in my pistons
Old May 19, 2005 | 08:19 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
The overlap in that cam will bleed off some cylinder pressure.
But with a good tune, you should be ok.
Old May 19, 2005 | 08:29 PM
thanks that puts my mind at ease. I'll probably run octane boost just to be safe and it wouldn't be past me to splurge on $6/gallon turbo blue. Just read an interesting article
http://www.hotrod.com/techarticles/72498/
Old May 19, 2005 | 10:14 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
according to the article, run 87 and some booster, you'll get better results.
Old May 20, 2005 | 03:33 AM
i saw that I was suprised
Old May 20, 2005 | 09:12 AM
Car: 1982 Trans Am
Engine: 383 chevy
i was too, but i honestly felt like if you're gonna run the booster, why not run the cheap stuff first? save more money in the long run. assuming you can get away with that, anyway.
Old May 20, 2005 | 09:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the motor is a "stock" 79 350, you won't have to worry about any 10.anything compression.
It will have roughly 15cc dish pistons.
With a more realistic .025" of deck clearance, and the actual properties of a "stock" 79 350, I come up with about 9.3:1 CR.
I don't think you'll have any trouble with it.
It would run better with the XE268; those heads can use the bigger exhaust lobe.
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
