spohn motor mounts
Old Jun 5, 2005 | 02:22 PM
Kandied91z's Avatar
spohn motor mounts
is spohn the only company that makes ls1 motor mounts?
anyone running spohn for their ls1 and have any problems or issues?
Old Jun 5, 2005 | 02:39 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I believe S&P make a set of adapters to bolt the thirdgen engine halves to your engine.
Old Jun 5, 2005 | 03:10 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
oww someone has alittle ls1 fever goin on over here..
Old Jun 5, 2005 | 03:37 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
s&p? do you have a link?
Old Jun 5, 2005 | 11:00 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I have the Spohn's motor mounts as well as his T-56 stuff (although they're not installed yet), and my opinion is if you're going to go with a LS1-related transmission, you'd better go with the same company motor mounts, i.e. Sphon MM and trans x-member/torq arm. Don't mix and match, otherwise you risk having things messed up because of the potential for different measuring points. I think most LS1 guys here run Sphon, as he has beefy stuff. If you want pictures of anything, let me know.
My
Old Jun 6, 2005 | 02:50 AM
Kandied91z's Avatar
well this is a daily so i'm only running a 4l60e. i know my crossmember needs to be modified which i can do rather quickly myself but i don't have the time to mess with the mounts so i'm concerned on where to go as i've learned over time nothing bolts right in on these cars. just want to limit my fabrication as much as possible so those of you running th spohn mounts if you have any insights on what was needed to make it truly work i'd appreciate it and if you are running something else please share where you got it.
thanks.
Old Jun 8, 2005 | 10:02 AM
LT1guy's Avatar
Car: 1987 Trans Am
http://www.hotrodlane.cc/
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
