Part number for 350...
Old Jun 6, 2005 | 05:18 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Part number and build!!!
What is the part number for a bare 350 block from GM. I'm in the process of doing a rebuild but I want to start from scratch, especially to avoid a "bad" used block and machine work. Where can I get a new block? I tried Summit Racing, but I'm not sure if their blocks would work with the newer style cams. please help!
will this block work?
http://store.summitracing.com/partde...0&autoview=sku
with this kit:
http://store.summitracing.com/partde...=KeywordSearch
and these hydrolic lifters:
http://store.summitracing.com/partde...CCA%2D853%2D16
Need suggestions please... Also, will I be able to salvage any of my accessories of the 305TBI, ANYTHING SALVAGEABLE? If certain parts were, I'de wait untill I have more money to buy them, maybe this winter... etc..
Old Jun 6, 2005 | 05:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Unless this is going to be a rediculous race engine, just use a junkyard block... the vast majority of them are in good enough shape to be used again with basic machine work, but they cost between nothing and like, $50. A new block will cost alot more than that.
Old Jun 6, 2005 | 06:02 PM
Dirtbik3r's Avatar
I understand that, but how much will the "basic" machine work cost? What if it fails a magnaflux test? But in case i do decide to go a new block route(maybe with a better rear/main), what is the part number?
Btw, whats the benefit of a 2piece or 1 piece rear main seal?
Old Jun 6, 2005 | 07:48 PM
Air_Adam's Avatar
I don't know the exact part number, but I know GMPP (GM Pref Parts) sells naked blocks, but they aren't cheap. Aftermarket blocks are even more expensive.
Typically, the machine work needed by a run of the mill junkyard block will cost less than buying a new block.
Old Jun 6, 2005 | 09:10 PM
Dirtbik3r's Avatar
I want to build it from scratch. If i can get a block for 6-7 hundred, will. Plus, all of the camaro's in the junkyards over here are rotted beyond belief and have a ton of milage. I'll have more confidence with a build on a new block. Also, I have a choice between a 1 piece and a 2 piece main if I go this route. Any suggestions on which would be a stronger and better choice? I have already found out the block I was looking into can accept hydraulic roller and flat tappets. So all I need to know is if a TPI intake or a stealth ram would fit correctly. I think it depends on the angle of the intake ports.
What are the pro's and con's of a one piece main compared to a 2 piece? The LT1's were a one piece and were considered an upgrade because of this over the l98's, correct?
Old Jun 7, 2005 | 12:36 AM
Air_Adam's Avatar
You can get a junkyard block for pocket change... but an aftermarket block will cost you a minimum of $1200. Then you can add probably $200 freight to that too.
L98 and LT1 are both 1-peice seal blocks. The difference between an L98 and LT1 is that the LT1 has aluminum heads, and more importantly, reverse-flow cooling system. That means the heads get cooled first, then the block. The L98 (and all sbc before) cooled the block first, then the heads.
The good thing about a 1-peice seal is that its less likely to leak than a 2-peice seal. Parts like flywheels, flexplates and cranks are more common for the 2-peice seal blocks though, because those blocks are much more common. Theres nothing wrong with a 2-peice seal though... I have a 2-pc seal 350 and it doesn't leak.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
