New adaptor to keep A/C
Old Jun 7, 2005 | 05:53 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
For my LT1 swap to keep A/C I ended up hacking a stock Corvette A/C line at a hydraulic shop but it looked like crapola and I figured there must be a better way..
Here is something a bit new
http://www.hotrodair.com/gmadaptor.htm
a nice adaptor that allows a screw in line to run into our compressors.. I talked to a tech, he knew the right connectors right off the bat, measured up the length that I needed and the hoses and fittings were sent already crimped and sized for the application with the adaptor..
not sure if I am late on this boat (probably) just thought I would post this, I could of used it a while back. I'll let you all know how it fits up when it arrives.
Old Jun 7, 2005 | 09:42 PM
ckeene502's Avatar
i need to find a way to put a/c back on my wifes camaro...i ripped it all off "to save weight". anyone know of a smallllll simple set up? the engine bay is to much roomier without it. but any options?
Old Jun 8, 2005 | 08:04 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Bit of a thread hijack don't you think? Since I am nice I will attempt to help however.
depends on how much money you want to spend, the company I mentioned above has one http://www.hotrodair.com/serpentine.htm street and performance can hook you up, so can march etc.. how much money do you want to spend? If that is a big factor just call up hawks or another used parts dealer and get the whole system from another thirdgen car for cheap.
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Mdenz3
Sep 17, 2015 08:36 AM
