timing problem. help!
Old Jun 9, 2005 | 01:28 AM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
ok so i put in a 327 at idle the timing has to be at least 36* advance for it to start do you think it is a cam to crank or a distributor issue or something else?
Old Jun 9, 2005 | 06:01 AM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Id should be around 10-14 degrees intial, TOTAL timing should be 36ish depending on your combo at about 2000-3000 RPM depending on your ignition curve.
Old Jun 9, 2005 | 08:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think you've got a problem with your damper timing mark and timing tab not properly lining up at TDC.
Old Jun 9, 2005 | 05:41 PM
Engine: 5.8
so when i pulled the timing cover I found that the cam was 180* off so I flipped it but when I went to start it the same thing happens when the to dots are Lind up it should be at tdc right if so then my marks are off if not I have no idea what is up
Old Jun 9, 2005 | 06:43 PM
five7kid's Avatar
The dots will line up on one rotation of the crank and then the cam will be 180 degrees off on the next crank rotation.
You can't get the cam 180 degrees off.
You need to check the location of the timing mark on the damper when the #1 piston is at top dead center.
Did you replace or mix either the damper of front cover?
Old Jun 9, 2005 | 07:26 PM
Engine: 5.8
well the balncer is off an 89 and the cover is a 74 the crank is a 68 so if it has changed over the years i thought it was the same for all sbc. is the cam was 180* off wauld it still fire up?
Old Jun 9, 2005 | 07:39 PM
kevinc's Avatar
Car: 1982 Z28
This was covered already, but here ya go one more time...the cam is "180* off" every other crank rotation. The cam spins at 1/2 the speed of the crank. You may have noticed the difference in size of the cam gear relative to the tiny crank gear.
The timing marks aren't identical in all SBC years, it's best to get a timing tab and balancer as a matched set to avoid mismatches.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
nuggie
Aug 25, 2015 01:27 PM
justin57
Aug 20, 2015 07:05 PM
mustangman65_79
Aug 8, 2015 12:07 PM
