Swaping into a different year
Old Jun 12, 2005 | 10:42 PM
Firedragon's Avatar
Car: 1991 V6 Firebird
Engine: 3.1 MPFI
Transmission: 700R4 Automatic
I have a quick question and i didnt know how to word it right to get a good search so here it is. When swapping in an engine, does it really matter if it is from 80-85 or 86-90? I am speaking in V8 terms. Also do i have to change anything under the hood to acomodate an 86-90 engine in an 85 trans am? I have been reading jegs and summit and they always separate these two sets of years. thanks and sorry for the dumb question.
Old Jun 13, 2005 | 01:04 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
simple answer:
no.
the only real difference to pay close attention to is to make sure your flywheel and starter match up, and that you have a crank and heads to fit the block. meaning, you understand that using 86-up heads means modifying an earlier intakes center bolt holes, or buying a new intake to fit the heads. but the blocks mount the same way in the engine bay, and bolt to trannies the same way, and can use the same gaskets and bearings and cams and stuff.
Old Jun 13, 2005 | 01:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You will need a different flywheel or flexplate. A 2 piece RMS flywheel can't be used on a 1 piece RMS crank and vice versa.
colton_carlson
Mar 8, 2019 12:21 PM
Cornholio7979
Sep 20, 2018 02:31 AM
92GTA
Apr 9, 2016 07:39 AM
Americanmouse
Sep 7, 2015 12:10 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
