Motor Swap Questions
Old Jun 23, 2005 | 12:04 AM
Catfootball62's Avatar
Car: 91 Camaro RS...GONE 87 SC (84 Z/28 clone)
Engine: 305 TBI LO3....GONE....305 TPI
Transmission: 700R4 with shift kit
Ok guys....ive done some searching on here and i think im ready to begin my motor swap (LO3 to 350 carb)i know this is asked alot...and ive searched...but i just wanna check to be certain on a few questions....
For the fuel system...i can use the stock fuel pump....but it would probably be wise to go ahead and change it though right?
The factory gauges can be hooked right up with no problems?
these are my main 2 questions though. (ill probably run into more as the swap comes along...) i wont have to worry about the TC lock up problem...because im getting a th-400 to go with the motor
but the fuel system is the one that really worries me...if anyone could elaborate a little further into detail of what i would have to do...i would really appreciate it...
Thanks in advanced,
Dennis
Old Jun 23, 2005 | 01:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you use the stock pump, you'll need to use a regulator to reduce the fuel pressure to a carb-friendly 5 psi or so.
Old Jun 23, 2005 | 01:28 AM
How difficult is it to install a regulator??
and am i correct about the gauges??....sorry for the noob questions...gotta learn someway i suppose lol......thanks
Dennis
Old Jun 23, 2005 | 01:38 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The gauges will be fine, you won't have to change anything to keep them working.
If you use a 3 port regulator, you'll just connect the inlet port on the regulator to the fuel supply line to the pump, the outlet port to the carb, and the bypass port to the return line to the tank. Not much to it.
Old Jun 23, 2005 | 01:55 AM
thanks
Thanks man i really appreciate it...i like knowing i can come here and get answer to all my noob questions quick and easy haha
Thanks again
Dennis
Old Jun 25, 2005 | 11:05 AM
ok ive run into another question....can i use my stock driveshaft with the th-400.....and if i can use my stock throttle linkages....
Dennis
Old Jun 25, 2005 | 11:16 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All versions of the TH400 are different overall lengths than the 700R4, so you'll need a different driveshaft. The mounting holes are also in a different location, so it also won't just bolt up to the 700R4 crossmember.
I'm not sure about the throttle linkage, you might be able to make something work though.
Old Jun 29, 2005 | 10:10 AM
can i just re-drill into the cross member and bolt it up...or will that weaken the structure or something of that sort??
I went to advanced the other day...and the only fuel pressure regulator they had was a 2 port....can i use this???
also does anyone else know if i could use the stock throttle linkages....
thanks for all the help
Old Jun 30, 2005 | 09:23 AM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Transmission: Turbo 400
Axle/Gears: Moser 9 inch/4.56 gears
Try Spohn Performance. They make a quality crossmember to adapt a Turbo 400 to a 3rd gen. They make it with and without torque arm provisions. I installed one in my car. Oh yeah, it also locates the level of the tailshaft correctly. Speaking of tailshaft, it takes the big yoke where the 700r4 takes the small yoke.
Boo.
Old Jun 30, 2005 | 10:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It would be better to order a 3 port regulator. The stock pump needs a constant flow of fuel for cooling. They don't like deadheading so much.
Old Jul 5, 2005 | 12:39 PM
well gettin the 350 and th 400 this week....going to replace all gaskets and seals on motor and tranny....just wondering if anyone knows of any major problems i may run into that i havnt thought about yet?
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
reiderz iroc
Aug 13, 2015 04:57 PM
