Ls6
Old Jun 27, 2005 | 05:03 PM
conman962's Avatar
Car: 91 formula
Engine: 305 tpi
Ls6
I have a question i am gettin an LS6 out of a 03 Z06 and i was wandering about the engine mounts if i could take thoughs or i would have to fab some thanks brycon
Old Jun 27, 2005 | 05:08 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
LS6 and LS1 are the same as far as motor mounts, you can use the same mounts that the guys putting the LS1 in the 3rd gens are.
Old Jun 28, 2005 | 08:31 AM
conman962's Avatar
Car: 91 formula
Engine: 305 tpi
alright thanks alot
Old Jun 28, 2005 | 01:04 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
the acutally mount on the engine you can use.. the clam shell or whatever they call it.. keep the long bolts too.. you'll need those too.. but the mounts that are in the k-member are no use.. you'll need special ones for our apps or a tubular K with ls1 mounts
and sinces its a vette you will need a new oil pan from an f-body and then everything from the flywheel back will have to be f-body as well
Old Jun 28, 2005 | 01:19 PM
Klortho's Avatar
Car: 1987 GTA
Ah, and one other thing as well, the Vette is a fly by wire throttle on the car, not cable. So you will have to either change the throttle body out, or put in a gas pedal with this setup on it.
Old Jun 28, 2005 | 01:51 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Dont forget that your gonna need to change the serpetine setup to an f-body as well.
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
sandman92084
Sep 12, 2015 10:27 PM
