350 4bbl or 350 TPI
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
350 4bbl or 350 TPI
Im currently running a 305 4bbl in my 82 trans am. Im saving up for a new engine but im getting mixed messages about whether to stick with the carborater or switch to fuel injection. Can anyone explain the benifits of having one compared to the other?
Transmission: 4L80E/4L80E
Your decision has to include input such as emissions testing/inspection yes or no, and intended use.
There isn't any reason your current system couldn't be used on a 350 and remain emissions compliant. It will run fine and probably make more power than a fuel injection system would, if all of the supporting equipment is properly chosen and installed.
Fuel injection typically yields better gas mileage. It can also be easier to start in winter, and have better driving manners. However, the cost to install such a system will require many miles to pay back the cost of the changeover with improved fuel economy (although that point will come quicker with today's fuel prices).
Car: 1982 Trans Am
Engine: 350 4BBL
Im just looking for street legal power. Would I need a new transmission if I switch to the 350 carb due to the horsepower increase. I belive I have a munzer (sp?) tranny right now.
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
if you have a 4-speed, (you lucky sumbitch) you have a borg-warner super T-10. if not, it's a th200c. (assuming it's stock, of course.) and you could definitely use it with a 350.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by Tripper511
i do have a 4-speed. Is that unusual for my car?
BUT - theres a catch... if you have the Super T10 setup, then you have a pretty stout transmission, and it should handle a pretty decent 350 just fine.... but the vast majority of the 4-speed cars (2/3 to 3/4 of them) did NOT get the ST10, but the Saginaw 4-speed. Its much inferior to the ST10, and won't last as long behind a stout 350 if you are mean to it.
The best way to tell the difference is to get under your car and clean off a small spot on the trans casing (not the side cover).... if the trans case is IRON then you have a SAGINAW. If the case is ALUMINUM then you have the ST10.
Car: 1982 Trans Am
Engine: 383 chevy
not unusual, just uncommon.the th200c is junk, get rid of it.. but if you have a 4 speed, i'd keep it. especially if it's a T-10. if it's not, drive til it breaks, and then put a stout 4 speed or 5 speed in it.
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
The 200c is not trash.
As for doing a TPI conversion to an 82, yes it vary doable. And can be very dependable. The trick is to plan, plan, plan!. The conversion is not cheap, but for everday driving its more desirable then a carb.
Here we go again another carb vs TPI thread.
Car: 1982 Trans Am
Engine: 383 chevy
I'm not getting in another "mine's bigger" discussion about the merits of TPI vs. Carb. that's not the question at hand. I'll agree that any transmission can be built, especially when a competent builder gets his hands on it. but for the money, why build a 200C when you can get a 700r4 to handle more power, it has OD, and is overall a better engineered transmission? but beyond my personal feelings, he has a 4-speed anyway. (lucky schmuck). I still think he should drive it til it breaks, even with a 350 with his induction of choice, and then replace the broken one with either a beefed version, a newer 5-speed, or an already beefier 4-speed (like a muncie or a richmond 4 + 1).
A 700r4 swap due to it overdrive would also required required a rear gear change. I would also had to have another drive shaft, transmission cross member, and touque arm. When you add up all of that stuff, its much cheaper to keep the 200c.
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Am I mistaken,or isn't the 200c just a light duty version of the 350?I was thinking the cases looked identical,but the differed internally.Just curious,not going to comment because wherever there's a car guy,there's an opinion of the "best" tranny.
As far as induction,IMO,I'd go TPI or another form of EFI.Yes,it's pricey,but sit down and figure up a good carb and intake deal,and so is that.I've got damn near $1000 tied up in my carb and intake.Not saying TPI makes more power,just that it's hard to beat the response and reliability of EFI,even if it costs a little HP.
Car: 1982 Trans Am
Engine: 350 4BBL
Unfortunetly if you have a problem with EFI it tends to be more expensive/complicated to fix and sometimes harder to dignose compared to a carb. Its electronics vs mechanical.
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
