A new meaning to "five7kid"
Old Jul 21, 2005 | 11:28 PM
  #51
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
We removed the bumper to get ours in! That long nose is a bugger with a standard size lift. Can't wait to see real photos!!!
Kurt
Old Jul 21, 2005 | 11:36 PM
  #52
five7kid's Avatar
Transmission: 4L80E/4L80E
5 lug nuts seemed a lot easier than the nose.
The other camera won't be back home until Monday night. So, the in-progress pictures aren't going to be very crisp, I'm afraid.
Old Jul 22, 2005 | 01:24 PM
  #53
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I delt with that problem with my first motor swap with the picker arm being too short, the car was getting redone, so we literally pressed on....picker into the nose cone that is LOL!! But the side option was the next plan of attack.
Since that time I purchased a AC Delco picker before I dropped in the 388...what a difference. I could easily put the arm at full extension into the 8' tall ceiling if I wanted to and I had PLENTY of clearance between the noe cone and picker body...it's a cheaper lift, but man does that thing work good, very impressed for only $200.
Good luck with the rest of the small crap that goes into this, hopefully everything will bolt/wire up no prob and the firing will go off without a hitch. be sure all grounds are hooked up and add some if your bored, we've gotten burnt a few times with those darn things.
Looks good
Old Jul 23, 2005 | 11:56 PM
  #54
five7kid's Avatar
We seem to hit little snags every few operations. I had tucked the speedo cable up in the tunnel while cleaning and moving the car around, forgot about it and smashed the end of the housing when I jacked up the tranny to put the crossmember in. That took about half an hour to straighten out. Then I discovered I had put the torque arm mount top bolt in from the wrong side, so I had to drop the tranny down and loosen the tailshaft housing to get that switched the right way.
We finished up underneath and dropped it back to the floor this evening. I have a few things done on top like the water pump, crank pulley, AC & PS, will get to the rest tomorrow (I hope). Still need to rebuild the carb. As I was looking things over before coming into the house I discovered I forgot to hook up the tranny harness . I'll do that with the first oil change (after getting it running, timing set, etc.).
We discovered that the new poly engine mounts did indeed raise the engine. So much that I had to cut off a corner of the passenger side A-arm mount to clear the y-pipe downpipe. Someone had asked me about that a couple months ago, I had plenty of clearance with the old mounts, no so anymore. Also put the pipe to the cat very close to the subframe connector. I suppose if I was doing this right, I'd cut & box the SFC, but I don't have a good way of doing the cutting. Do poly bushings ever sag?
Here's a picture of my new free-flowing tubular cat.
Old Jul 24, 2005 | 09:01 AM
  #55
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Five 7, are them engine mounts going to cause a hood clearance problem?
Auggie
Old Jul 24, 2005 | 09:11 AM
  #56
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
"Do poly bushings ever sag?"
They might,but I don't think it will be in our lifetime!
Old Jul 24, 2005 | 09:52 AM
  #57
five7kid's Avatar
We'll have to see about the hood clearance. The air cleaner wasn't actually hitting the hood blanket, so it may still be okay. I think what has happened is the engine is not only sitting higher, but has been shifted side-to-side. The tranny mount was weird before, requiring slotting of the crossmember to get the center bolt in, but now fits within the original slot.
I think I'm going to drop the y-pipe and go ahead and take the high speed electric angle grinder to the SFC to get the needed clearance. Not something I look forward to, but something I should do.
Here's my son Nate installing the starter. That was another of our snafus, the S terminal nut got started crooked, and eventually broke off. We spent an hour and a half finding another solenoid. The one that was on the starter didn't have the R terminal we could rob, and I couldn't locate a "spare" within my vast spare parts inventory (it was about 130 degrees in the garage attic, that may have contributed to the failure to locate).
Old Jul 25, 2005 | 10:57 AM
  #58
five7kid's Avatar
I dropped the y-pipe and cut an "L" shaped length from the SFC with the cut-off wheel. I didn't have time to remount the y-pipe to verify clearance, but it should be okay (I hope - that cutting process wasn't a whole lot of fun). I'm going to reverse the piece cut out and weld it back in to "box" the cut out portion.
I also connected the transmission harness while I was under there.
Progress is slow, but there is progress.
Old Jul 26, 2005 | 01:43 PM
  #59
five7kid's Avatar
Last night was another example of why this is taking so long. I fit-checked the y-pipe, clearance fine, so I cleaned up the edges of the cut-out piece, vice-gripped it in place, tacked it in, re-fit checked the y-pipe. Everything looks good, so I proceed to run beads around all the edges. Had to add some filler metal to the ends to close them off, used a big flat washer cut to size for that, was in the process of finishing the closure welds when the welder ran out of wire. Too late to get some from the stores, but too early to quit working. I chose the latter and got myself cleaned up.
The rest of the week typifies the other reasons this is taking so long - celebrating daughter's birthday tonight, son's horse riding tomorrow evening, appointment Thursday night, anniversary Friday night, more horse riding Saturday morning.
And the horse trailer towing van transmission is making a funny noise now.
And the beat goes on...
Old Jul 26, 2005 | 01:48 PM
  #60
Auggie's Avatar
I hear yah man I hear yah
Auggie
Old Jul 27, 2005 | 11:41 PM
  #61
five7kid's Avatar
Finished the boxing tonight and got it back together. After getting it all painted up and re-attaching the y-pipe, I discovered I needed to cut off the front corner as well. (sigh...)
This represents 3 evenings of work. I know, lousy welds, but that's using a hobby-quality flux core wire welder and laying on your back with sparks going down your neck. However, I've gotten worse welds that I paid to get done, and they had professional quality MIG equipment.
Old Jul 27, 2005 | 11:52 PM
  #62
five7kid's Avatar
A view from under, looking to the rear. Tucks up pretty nicely, I think.
Attached Thumbnails A new meaning to "five7kid"-exhaust-ground-clearance1.jpg
Old Jul 28, 2005 | 12:46 AM
  #63
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
wow, that tucks up there REALLY nice...
Old Jul 29, 2005 | 08:53 PM
  #64
five7kid's Avatar
Today was an off-Friday from work. After running a few errands in the morning, I was able to get out to the garage a little before noon to continue the topside work.
1st was swapping the distributor gear with the '57 - it has a ZZ3 distributor in it, since that was the same cam as I'm using in the Camaro, seemed to make sense to use that gear.
I was getting ready to install a new alternator when I discovered I needed to rotate the housing. In that process, the brushes slipped out, so I needed to separate it completely to get the brushes back in - then discovered this "all new" alternator was the victim of a brush swap. So, back to the parts store to exchange that. Then the "new" Car Quest water pump didn't have the top heater hose angle quite right, so I had to modify the top alternator bracket to clear the heater hose.
Left is carb rebuild and attaching what attaches to it, add fluids, then maybe actually trying to start it later this weekend.
Old Jul 30, 2005 | 08:12 AM
  #65
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
I noticed you used a load leveler to put your eng/trans in. Do you know about how much ceiling clearance is needed. The ceiling in my garage is pretty low 7 foot 8 inches. I pulled the eng/trans out without a leveler and had a few inches to spare. But when I do the install I'd like to have the headers on.
Old Jul 30, 2005 | 09:39 AM
  #66
IHI's Avatar
IHI
We used a load leveler 3 times and have been using the carb plate ever since. The lever principal is nice, but you do lose clearance with ceiling height, our shop we all used to use that was a non issue, but new one it's a big issue.
Best advise if purchasing one, get rid of the hand crank, it'll take forever to adjust, and install a nut that you'll weld to the end of the thread all that moves the cariage, this way a simple air ratchet will expediate the process.
A $15 carb plate, or even a home built unit has served the purpose with for all our motor swapping needs and we'll never try a leveler again, PITA, IMO.
Old Jul 30, 2005 | 01:14 PM
  #67
five7kid's Avatar
Our ceiling is 8', but we pushed the car half-way out to give more working room in the front (since we ended up going in from the side, it didn't matter). The hoist ended up under the garage door, which is another 6" or so below the ceiling, and we didn't hit it.
The bigger issue was hitting the firewall lip with the leveler as it was almost in. Had to wrestle it by a little, but managed.
Old Jul 30, 2005 | 11:22 PM
  #68
five7kid's Avatar
Got the carb rebuilt. Took a little under 4 hours, taking my time (and not counting taking the air horn back off after finding the pump check ball that had been hiding from me during reassembly).
No real surprises, although this was a little disappointing.
Old Jul 30, 2005 | 11:24 PM
  #69
five7kid's Avatar
Oops, hit "Submit" instead of "Browse..."
Old Jul 31, 2005 | 12:15 AM
  #70
five7kid's Avatar
I guess it's time to retire this thread. The "rest of the story" will follow on https://www.thirdgen.org/techbb2/sho...hreadid=312746 .
morrow
Jan 13, 2024 12:29 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
Damon
Sep 26, 2015 04:29 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
