starts and stalls after TPI swap
Old Jul 8, 2005 | 10:56 PM
bltranam's Avatar
Car: 86 Trans Am
Transmission: 350
I just finished swaping a 350 TPI motor from an 88 bird, into a 89 TBI 305, the motor ran in the car it was in before. However, now it starts, runs for about five seconds, then stalls. I swaped the wiring and ECM but didn't switch any fuel stuff. I know that TPI's operate around 40 PSI and TBI's run 15PSI, but it seems strange to me that that would make it stall. Any advice or insight is appriciated. Thanks.
Old Jul 11, 2005 | 11:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need the pressure.
Old Jul 11, 2005 | 11:49 AM
kevinc's Avatar
Car: 1982 Z28
I know from experience the difference in engine behavior at 30psi versus specified 45psi is significant...get a TPI pump in there.
Old Jul 12, 2005 | 10:07 PM
silverta8702's Avatar
sounds like a vats issue
Old Jul 13, 2005 | 05:39 AM
kevinc's Avatar
Car: 1982 Z28
Sounds like someone doesn't know what they're talking about.
Old Jul 13, 2005 | 01:43 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
the pump doesnt control the pressure.. the regulator on the rail will a tbi pump is probably not ideal but it should work, try a fuel gauge to see what you get on the rail
did you swap in tpi fuel lines as well?
how does it run before it dies?
Old Jul 13, 2005 | 02:54 PM
kevinc's Avatar
Car: 1982 Z28
The regulator on the rail doesn't create volume, the pump in the tank does.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
