305 to 350 swap
Old Jul 9, 2005 | 06:18 PM
chevrunner21's Avatar
Car: 1992 trans am
Engine: 305 tpi
305 to 350 swap
i wanted to know besides the motor what else would i have to buy to swap from a 305 to a 350? and also does any one have a nice ready to run 350 or 400 c.i. 4 bolt main motor?
Old Jul 9, 2005 | 09:39 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
I got a nice ready to run turn key nitrous ready 355 for ya. It will come with everything ya need turn key, including accesories, ignition and carb. If your interested ill PM you my number and we can talk and run some numbers.
Old Jul 12, 2005 | 10:05 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Re: 305 to 350 swap
chevrunner21,
That depends on what kind of 305 you have. TBI? TPI? Carb?
If your going Carb to Carb you need almost nothing.
Sincerely,
Kurt
Old Jul 13, 2005 | 12:04 PM
Parrydise7's Avatar
You may want to consider the search function. You aren't the first to ask that question (and, unfortunately, you won't be the last).
Old Jul 13, 2005 | 07:21 PM
Car: 1992 trans am
Engine: 305 tpi
swap
it's a 305 h/o carbureted to a 350 carbureted. i was originally given false information when i made my account on here the cars an 84 t-top iroc with 305 h/o and the car is badged 305 h/o and it is automatic.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
