Older 78-85 4 bolt main motor in 89 IROC? SMOG?!?!?
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I have the opportunity to purchase a very nice shortblock. But it is an older 350. appx 78-85 block. Can I basically use the TPI on this engine and still pass smog? I will only be using a relatively mild cam and some better heads along with probably a widemouth intake and some porting to an otherwise stock top end. Will it pass smog? I live in california and am worried about this. My engine doesn't seem to be doing so well, and I have been wanting to replace it with something more solid for quite some time now. Anyways, thanks in advance fellas
Will
Will
Car: White KSwisses
Engine: 5.3L Gen III
Yea, you can use your TPI and pass smog if you switch everything over.
What are you going to do about the 2 piece rear seal?
Also, its not a roller block, so you have to get a flat tappet cam and lifters...not cool.
Can you elaborate on the roller part. Obviously I know the two are 1, hydraulic roller and 2 flat tappet. but what exactly does that mean? Thanks man
Will
Will
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The motor you have right now uses a 1 piece rear main seal, which is not prone to leaking like the 2 piece main seals are. As for roller vs flat tappet
Roller lifters is just what they are, they have a roller on the end of the lifter which goes around the cam lobes, letting the lifters ride the cam easier freeing up hp and doesn't create as much wear.
A flat tappet has a flat bottom on the lifter which runs on the cam lobe, the lobes are not as steep an angle as roller cams are, but can rob you of a bit of hp and the cam lobes can wear faster than a roller.
All 86+ blocks in the f-body and Corvette are roller cams and 1 piece rear main seal.
Transmission: 4L80E/4L80E
mustangman65_79
Aug 11, 2015 03:17 PM
