Fast Responce Needed!
Old Jul 17, 2005 | 07:35 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
ok this guy wants to sell the following engine for 100.00 as follows
http://cgi.ebay.com/ebaymotors/ws/eB...3ARTQ%3AUS%3A1
i currently have a 305 that sim replaceing, woudl it be easier to stick with a 305 or go with a 350 ..
if i went with this 350. What would be needed to be done for it to work in my car.
thx guys i need a responce asap. thx
Old Jul 17, 2005 | 07:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
As I replied to your other topic:
The two 350's you posted are 1970's Era, which is about the peak of low performance V8s and would probably only worth the block itself, if not already worn out. They also have a 2-piece rear main seal which in most instances are less desireable.
Also note that it says it sat in a garage for 8 years. If not prepped properly, it could be in worse shape then what you have, assuming it was good before being stored. An engine that old, if still stock, probably needs valve stem seals, gaskets, etc...
Old Jul 17, 2005 | 07:44 PM
Engine: V8 350 ci
ILL KEEP LOOKING, BUT CAN U AT LEAST TELL ME WHAT WOUDL I WOUDL HAVE TO DO TO PUT A 350 IN MY CAR? WHAT THINGS WOUDL HAVE TO BE DONE FOR IT TO WORK. BECUSE I MIGHT GO TO A WREAKIGN YARD AND GET ONE, OR IF ITS TOO MUCH TROBLE ILL JUST PICK UP A 305 FROM A WREAKIGN YARD.
Old Jul 17, 2005 | 10:01 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Dude,are you dislexic or something?
Assuming your talking about swapping longblocks,as in a complete engine pan to intake,swapping in a 350 will be the exact same process as putting in a different 305.
Now,do us all a favor,and sit down with a dictionary.Pick out every word that you use,and learn how to spell it properly.
Thank You
Old Jul 17, 2005 | 10:13 PM
net_coma's Avatar
You need to find one that is compatable with your car. If you intend to retain the emissions then the 70's stuff is no good to you. Find one that is the same vintage as your car, if it is high milage and even if not...get a repair manual and start reading, learn to use a mic and calipers...tear it down check it all, get new parts as dictated by your measurements and the standard stuff...oil pump, bearings to the size after the machine shop is done with you crank, block and connecting rods....read the overhaul section until it is memory, check everything twice then look again....it is not hard but if you don't do your homework then you will suffer a hit in the wallet along with the embarassment of taking something hosed to a mechanic to have it all sorted out. Get a bood.........read read read and read the posts here. Then you will be ready to start thinking of what you can do that you want to do. If you get one that is low milage, trust but verify.
Old Jul 17, 2005 | 10:43 PM
Engine: V8 350 ci
Thank You
So if i find a 350 complete from oil pan to intake it will just bolt right into my camaro with useing the 305 stuff? will i need diffrent headers and xhuast too? and will a 350 bolt up to a 700r4 tranny?
Old Jul 17, 2005 | 10:51 PM
Irockz's Avatar
Anything that will bolt to a 305 will bolt to a 350,aside from pistons and rings.Headers,carb,dist.,anything that is on your 305 will bolt to a 350.Just be sure not to buy a junk engine,you already have one,or so you think.Did you ever crawl your young *** under the car and look at the flywheel?
Old Jul 17, 2005 | 10:56 PM
Engine: V8 350 ci
yes teh flywheel is good, and why not get a 350 from a wreaking yard.....they go for 300-400 with 90 day warrenty. Also ar eu sayign i gonna need a diffrent pistons and rings.Headers,carb,dist? i dont see why i have too becuse im getting a COMPLETE 350 form oil pan to intake therefore it shoudl only ned to bolt up to my exhust and tranny and computer ect.
Old Jul 18, 2005 | 07:40 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
He didn't say you needed new pistons, he was referring to the fact that a 305 and 350 are both Small Block Chevys and therefore all external components (oil pan, intake, distributer, etc...) will bolt to the exterior of the engine. They are dimensionally the same, so you can use the same motor mounts, same exhaust, same accessories and same transmission. He was referring to the internals, such as the pistons, that are different between the two engines, but since you are buying a complete engine, that doesn't pertain to you.
Wreaking yard engines are OK, but don't forget, your usually replaceing a high mileage engine with another high mileage engine, so who knows how long this one will last. The 90 day warranty is great, but it doesn't pay for labor or ancillary items like intake gaskets and fluids should you need to yank it again.
As for what to look for, try and find something close to the year range your in. If you have a '91 and put in an '85 engine, then you need a different flexplate and you'll also have to modify the intake manifold to get the bolt angles correct.
I don't mind helping the best I can, but reading some of your posts makes my head hurt. Assuming you are native to the US, you should be embarrased to not write the native language fluently.
Fast355
Dec 2, 2016 06:33 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
