swapping a motor got questions
Old Jul 18, 2005 | 07:38 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
hey guys i have a 86 trans am with a 305 tpi, i have a brand new 350 tbi motor for it. i want to keep the tuned port setup though. i did a 305 tbi to a 350 swap before and changed injectors, knock sensor, spark module, and i had to get a chip. what all would i need for putting the 350 tbi motor in the 305tpi car?
Old Jul 19, 2005 | 12:17 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
350 TBI heads are pretty terrible. You'd be better off with your current 305 heads with 1.94" intake valves on the 350 shortblock.
What you should have are 22lb injectors and a 350 knock sensor and module. An L98 chip wouldn't hurt, either, but the 305 chip would probably handle it.
Old Jul 19, 2005 | 06:09 PM
Car: 89 trans am
Engine: 355
alright i pretty much knew all that had to change just double checking on the injectors. so i could go and get injectors for a 350tpi and use them or the 22lb injectors?
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
reiderz iroc
Aug 13, 2015 04:57 PM
