mounting AC compresser and PS pump
Old Aug 1, 2005 | 10:23 PM
poncorick's Avatar
Car: Fiero, Trans Am and GTO
Transmission: auto
I got a 1987 Trans AM with the engine torn a part and now I have put a 305 tpi engine in but do not know what kind of brackets or how they mount up. I know they go on the left side with the AC compresser above the PS pump. Can anyone tell me what mounts I should have? If anybody has pictures showing this I would appreciate it.
Also are there any detailed wire diagrams for these cars that would help me on figuring where all the wires hook up?
Thank you,
Rick
Old Aug 2, 2005 | 10:12 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Hope this helps....
poncorick,
These are from a Carb '82 (sort-of).
Attached Thumbnails mounting AC compresser and PS pump-z28_bracketstgo_080305.jpg
Old Aug 3, 2005 | 01:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They will be the same for the '87.
Except the small bracket that mounts to the front intake manifold mount bolts won't be a lifting eye (but if that's what you find, there's no problem with that).
Old Aug 3, 2005 | 09:35 PM
poncorick's Avatar
Transmission: auto
Thank you for your help, I seem to have the brackets but had no idea of how they bolted up and for what the brackets were for.
The pictures have been a big help.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
