The wire sort boogie
Old Aug 5, 2005 | 07:48 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I have started sorting out the wiring harness on my 91 rs. It had the 305 tbi. I'm halfway through it and have a few of questions.
1. Under the dash there are the plugs for the ECM. A smaller bunch of wires split before the ECM and went into another plug What do these wires control? I remember several of them being pink, pink with black stripe, etc
2. The wiring harness reenters the firewall on the driver's side. What do these control?
3. It looks like the A/C and heater is controlled by the ECM. How have you hooked these up?
I'm hoping to have this rust bucket rolling by mid September.
Old Aug 5, 2005 | 07:26 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
We can provide SOME Help
We had the same wires and have NO idea what these are for.... We left them alone..SORRY
The smaller connector (left side facing from the front of the car) is for the front lighting and the sensor on the brakes...Don't think there is anything else on that one. It should thread over the front driver's side fender and to the lighting.
The larger connector is for; Wipers, Dizzy Connections, Alternator, Starter, Temp Sensor, Etc. (It provides power to #3). It should be threaded around the rear of the engine and then down the top of the Pass Side Valve Cover. It has one or two connections to the MONSTER strand from under the passenger side fender (The ECM Strand).
The A/C & Heat Strand (in our '82) is almost completely independant of the other strands of the harness. I don't think there is any relationship to the ECM. The strand one Red wire quick connect that links it to the Big Strand from #2. Otherwise It travels around the fan & Condensor and back into the car behind the Pass Side Head and into the Rear of the Controls on the Console.
Hope this helps SOME.
Old Aug 6, 2005 | 04:39 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
get some pics. I'm sorting out teh differences between the 85 efi v6 dash wires & the 84 carb v8 dash wires. There's that strange blue box taped to teh harness, & an AC delco black box (flight recorder?).
Maybe the 85 Service maual will help some.......
Old Aug 6, 2005 | 08:14 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The AC/Delco black box is the cruise control box. Your '85 V6 harness should be the exact same as my '86 V6 which is totally seperate from the bulkhead connector. When I put the LT1 in mine, I totally removed all the old ECM and wiring and running the car totally on the bulkhead connector which if you are going carbed, this would be the way to do it with the V6 bundle.
Old Aug 6, 2005 | 08:24 AM
vrtc350's Avatar
Car: 81 Corvette
Thanks kboehringer!
That gives me an idea of what is what. I am half way through this process. I will be out there today and I will see about getting some pics. I don't know how much they may help. All the wires going directly to the ECM have been cut to make it easier to sort though them. Luckily, my Dad has done this with his 83. However by 91 the ECM had more control.
Thanks for the replies gents!!
Old Aug 6, 2005 | 02:59 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Do you need some mitchell diagrams of 85' camaro underdash and engine compartment?
Street Lethal
Apr 30, 2019 12:14 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
