305tpi to 350tpi
Old Aug 6, 2005 | 12:34 PM
jeremys82c10's Avatar
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
Axle/Gears: 8.8 w/3.08's with a trac-lock
305tpi to 350tpi
what all do i need to do this, i am thinking about gettin an 88 iroc-z with a 305 tpi,from what i have read 305's arent the best, i have had a non tpi 305 before and i know it wasn't as good as a 350
Old Aug 6, 2005 | 05:59 PM
88 Ram Air TA's Avatar
Engine: 305 5.0L F engine code
There have been countless threads on "305 tpi to 350 tpi." Seach.
What you could do is get a replacement 350 from someplace like http://www.rebuilt-auto-engines.com/...46&p_catid=111
And swap the intake on. Get 22lb injectors a knock sensor for a 350 and the computer chip for a 350.
Old Aug 7, 2005 | 01:05 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Re: 305tpi to 350tpi
jeremys82c10,
You don't even own the car yet and you want to change the engine?
If you purchase this vehicle, and it has been properly maintained and is operating as designed. You will be pleasantly surprised how much more powerful the IROC TPI 305 is than the Non-TPI 305 you owned previously.
Those IROC's are EXTREMELY good performers and the TPI is IMPO is a very very good set-up, probably the BEST set-up the factory installed on a Third Gen.
IMPO - Changing the engine on a TPI car for those few extra cubic inches (when/if there is nothing wrong with the 305 that is in it) is an expensive and dumb move. That's just my personal opinion.
Sincerely,
Kurt
Old Aug 7, 2005 | 02:07 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
I think your permanantly addicted to thirdgen.org Kurt, I see you posting more and more. Buy a fixer upper thirdgen and get an addiction to thirdgen.org for free, its like 2 for 1.
Old Aug 9, 2005 | 02:52 AM
Trippinhrd's Avatar
Car: '86 T/A T-tops
Engine: '86 305 TPI (stock)
I was thinking about swapping out my 305 tpi for a 350 but i was wondering... is it possible to use the stock tpi setup on a crate 350?
Old Aug 9, 2005 | 07:55 AM
Yes it will. Just make sure that the crate engine does not have vortec heads. GM is making a lot of crate engines with vortec heads. Another thing if you are actually going this route make sure you port the plenum, runners, and base. And just make sure you do not get a high performance crate because the TPI will choke it on the top end.
Old Aug 9, 2005 | 07:54 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
The way I look at it, if the car is your daily driver, keep the fuel injection. If you want a mild performing car, keep the tpi and do some porting or buy larger runner, base, etc. If you want to go fast with spending the least amount, go carb. So technically you could put a crate engine under it, but it will be a waste with the stock setup. Already as mentioned a lot of crates have vortec heads, you can by a baseplate for the tpi system, but its again more $. Then you have to tune it, easiest route would be diy prom burning. I just went to big for the tpi system, and didn't feel like spending $1000 or more just to get the intake system up to par.
Old Aug 9, 2005 | 09:30 PM
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
the person who has it now said the owner before him had the engine rebuilt and is and has been properly maintained, it also has brand new exhaust,balljoints and new struts, it also has a newer paint job
Old Aug 10, 2005 | 09:07 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
In '88, the automatic version of the LB9 TPI 305 didn't have as good a cam as the 5-speed version. But, it isn't that bad, and will probably have more power than the non-TPI 305 you previously had. If you want to up the power, do a cam swap.
Old Aug 10, 2005 | 09:41 AM
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
i just found out kast night i've had a 350 all along
86iroczwv
Sep 3, 2015 06:21 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
rdog30
Apr 6, 2001 07:07 PM
Stell1579
Aftermarket Product Review
Oct 11, 2000 10:47 PM
