What flywheel with 400 and a T-5
Old Aug 7, 2005 | 11:33 AM
91RedRagtop's Avatar
Car: 1991 Firebird Convertible Horsepow
Engine: 406 w/Motown 220 heads
Transmission: 5 speed manual
I'm going to be putting in a 400 SBC sometime in the near future and can't seem to get a definite answer to this question . Do I need to have the rotating assembly balanced ? Is there an aftermarket flywheel I can buy that will just bolt on and go ? Or what ? I tried a search and didn't find the answer to this .
Old Aug 7, 2005 | 03:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Having the crank internally balanced would certainly put the issue to bed.
www.summitracing.com , p/n CTF-700102. 153 tooth, external balance, 10.5", 29.90 pounds.
Old Aug 8, 2005 | 06:52 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Get a flywheel from an early T-5 car(2 piece rear main seal),and buy a bolt on weight(bolts between the flywheel and the crank).I've used these behind both 454s and 400s with great success.Speedway,Summit,Jeg's,or your local driveline shop should be able to accommodate your needs.
By the way,DO have it balanced,it makes a lot of difference in 383s and 400s,just don't worry about having it internally balanced,mallory metal is VERY expensive.
Old Aug 8, 2005 | 07:11 PM
A friend of mine says to just have the crank balanced . That will work too , right ?
Old Aug 8, 2005 | 07:26 PM
Irockz's Avatar
It will work,and is probabley the better of the two options,but be forewarned,that it is VERY expensive.
Old Aug 11, 2005 | 05:40 PM
aimless's Avatar
Car: 86 Z28
Engine: 400
Transmission: 5 spd
Hi I plan to do the same thing. I contacted a Hi-Perf store in the city I live in maybe 6 months ago and they said the would sell the proper flywheel for $300 Canadian or so. This is a brand new flywheel balanced and ready for install. The company name is Mopac, I'm sure you could phone toll free or just ask over the internet. Aimless
PurelyPMD
May 5, 2016 04:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
