Hey all,
I just have to present a question here so that I can get an idea of what is needed to be done in order to get my car going.
Were any of you able to use the stock V6 wiring harness with the V8? The only thing that has me bugged is getting power to the coil thats in cap. My v6 had the remote coil. Someone tore off my labeling quite nicely
and now I don't know which wire will go into the cap. If anyone can offer me some advice, I'll appreciate it.
and now I don't know which wire will go into the cap. If anyone can offer me some advice, I'll appreciate it.Supreme Member
Yes You can use the wiring harness.
Depends though if you plan on going carb, or FI.
I'm going from a carbed 2.8 to a carbed 5.7. My friend is telling me I need some 4 pin connector to go to the coil, but I don't have one in the harness... There is however, a grey connector that has a fat red wire... would that be going to the coil or module?
My manual sux and I don't have a helms... trickster helped me a while back but i dont think he gave me a wiring diagram for my car
You need an ignition on source for the coil. On my '88 is was a fat pink wire with a black stripe.
for coil in cap = just need the pink wire a ground and your tach. then you need the plug in connector between your dizzy and the cap but that should aleady be there. tach should be a smaller tanish wire and ground is black.I'm going from a carbed 2.8 to a carbed 5.7. My friend is telling me I need some 4 pin connector to go to the coil
The wires/connector coming from the dizzy.... I think the module... where does that go to? I don't seem to have anything in my harness that connects to it...
THEGENERAL
close
- Join DateApr 2004
- LocationStaunton,illinois
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
- Engine283, 2.5,3.8 turbo 350
- Transmissionpowerglide,auto overdrive, th350,4L80
- Liked:0 Times in 0 Posts
Quote:
back up into the cap behind the power and tach wires...Originally posted by ThUnDeR2005
lol ok, I thought so.
Now the fat pink wire, that will go where? Next to the module connector facing the front of the car?
look on the top of your cap. hook it to the terminal that says bat. the middle i think is the ground the other is tach.
What color connector is the ground wire? black?
yup, most times it grounds with the braided wire that runs from the firewall to the engine.
I have a double wire braided ground that came from the harness that I put to the back of the head. Same deal?
yup
