Old Aug 25, 2005 | 06:36 PM
Batts's Avatar
Hi, I have a 1983 Trans Am original 305 Cross-Fire Fuel Injected, I want to swap it with a 350 Tuned port motor from a 87 GTA. Motor is complete, including pulleys, alt, a/c, p/s, exhaust manifolds, dist, engine harness, computer, complete injection, mas air sensor, and motor mounts. Will this work will I need to change anything else?? Fuel Pump, exhaust system, catalytic converter?
Old Aug 25, 2005 | 07:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Fuel pump would be the only "need". I'm not completely sure about the fuel lines.
Exhaust is dependant upon whether or not you want to get the most possible out of the engine. Doesn't matter which engine you're talking about in that case.
Oh, did you get the air inlets/filters as well?
Old Aug 25, 2005 | 07:45 PM
Batts's Avatar
What air inlets/filters are you talking about? Sorry not that familiar with engines.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
