350 TPI to 454 turbo.
Old Sep 6, 2005 | 06:02 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
It is a long thread about this project in the Power Adder forum.
https://www.thirdgen.org/techbb2/sho...hreadid=217973
( Click to enlarge )
Before:
After:
It ia a 454 with
* Forged Steel Crankshaft
* Speed-Pro Power Forged Pistons
* Eagle ESP H-Beam Connecting Rods
* Holley EFI single plane intake manifold
* Set of 8 injectors 150 lbs/hr
* 80mm Throttle Body
* Megasquirt
* EDIS-8 ignition
* Holset HX-50
Crank trigger wheel. The sensor is behind the water pump pulley.
Two dual waste spark coils.
A th400 instead of the th700r4 ( R.I.P )
A 4" exhaust.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
