L98 aluminum will they work :confused:
Old Sep 13, 2005 | 03:52 PM
CamaroSpeed's Avatar
Car: 1987 IROC
Engine: 305 Tpi
Transmission: 700r4 With B&M Rebuild Kit & 2800 S
L98 aluminum will they work confused
Can anyone tell me if L98 aluminum heads off a 1987 350 tpi vette will work on a 1987 350 tpi camaro. If not which one's will.
Old Sep 13, 2005 | 08:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They will work. The iron head 350's have an exhaust "cross over" passage that is used to feed the EGR valve. The aluminum heads do not, and the factory used an external tube to go from the the exhaust manifold to the intake base. If you use a Vette base, you can accomplish that task on an f-body.
Old Sep 13, 2005 | 08:29 PM
chesterfield's Avatar
Car: Pontiac
I'm away from home right now so I can't look this up so I'm working from my feeble memory. The aluminum heads don't have the change in intake bolt angles that came in '87. They're still pre-'87 heads. I think these are them from mortec.com
"14101128...86-87...350..........Aluminum, 58cc, angle plug"
I could be wrong, but I think PAW lists them in their catalog.
Old Sep 13, 2005 | 08:38 PM
five7kid's Avatar
That is true, too. The intake mount bolt holes are all at 90 degrees, unlike the '87-up iron heads.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
matthew911
Aug 12, 2015 09:38 AM
z28addict8490
Aug 7, 2015 08:48 PM
