84 T/A: Stock Cover for Flexplate Need Swapped?
Old Sep 15, 2005 | 04:10 PM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
My new 350 in my 84 T/A also has a bigger flywheel - 168 tooth as opposed to the stock 153 tooth. There's a cover that bolts up underneath the car to protect the flywheel. It's hard to tell for sure, but it looks like the stock one might not have enough clearance inside with the bigger flywheel. My question is: Has anyone put a 168 flywheel on their T/A and were you able to use the stock cover? If not, where do you buy a replacement one?
Thanks,
Joe
Old Sep 15, 2005 | 09:56 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Is there any reason why you didn't use the original flywheel? I know these things are quite interchangeble. I just put the flywheel off my 87 IROC onto a 92 corvette engine. The original cover went back on fine....
Old Sep 15, 2005 | 11:37 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I dont know if it is the "right" thing to do, but I have a 95 LT1 and I dont even have a cover on it. Its been like that for a while with no problems. Its pretty thin and probably wont "protect" much anyway. Just be cautious when driving on anything but a paved surface.
84z96L31vortec
Aug 20, 2017 12:16 AM
NBrehm
Aug 25, 2015 11:49 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
