305 tbi system to tpi system help
Car: 1992 camaro rs
Engine: 305 tbi
Transmission: 5 speed
i currently have a 1992 camaro with a 5.0 tbi 5 speed stock set up. i recently purchased a tpi manifold with runers, plenum, throtle body, injectors, distributor, vacum lines and i think thats about it. i did not get an ecu or ecm whatever the computer is called i forget because i didnt know if it would work because it is for an auto and i have a 5 speed so if you guys could help i could use a few pointers to start my shoping list thanks
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
me to
I'm looking to do the same thing I think
you need a 45psi pump that sould work in your tank
(holley)
new fuel lines, they kind of splice on
(holley)
they also make piggy-back harnesses and a chip too
I dont think you need to change the computer
Holley makes all this stuff for one of their port injection upgrade kits (part #s fail me)
The kit comes with all this stuff to reuse tbi parts (like the throttle body w/out the injectors)
I'm trying to figure out if it'll all work on my motor (90 tbi 5.0) with the tpi setup
(holley)
(holley)
Car: 1992 camaro rs
Engine: 305 tbi
were did you order all those holley parts and if i have a tpi throtle body i shouldnt need to use the tbi one? right? and that holley kit comes with all the wires for all of the injectors and stuff thanks for the help
Im saying that holley makes this kit to convert TBI to port inj using the tb but you could order the parts seperate and use your plenum runners base and tb
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
sort of on topic:
I currently have an 85 car swapping in a carb. It has the v6 fuel pump init. I was going to be swapping in an 87 carb system using an 84 harness.
I have a line on an 89 tpi setup w/harness & ecm. Is this compatable w/the 84 dash harness, or will there be some issues.
I think there will be some power leads I'll have to rewire as they show on the 85 fulie fuse block, and not the 84 carb.
