Engine oil cooler question
Old Oct 4, 2005 | 07:37 AM
GTA350JAG's Avatar
Car: 02 Z28, 78 Z28, 86 Iroc
Engine: 346 LS1, 350 Goodwrench, Vette 350
Transmission: M6, T 10, 700 R4
Where do you hook up the engine oil cooler at the water pump? I dont have anywhere to hook it up from the waterpump I might have the wrong one or does it go somewhere else?
Old Oct 4, 2005 | 10:22 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I have never seen a camaro oil cooler that hooks up to the water pump.
Old Oct 4, 2005 | 10:44 AM
GTA350JAG's Avatar
Where does it go?
Old Oct 4, 2005 | 11:52 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Usually to the radiator. Only if the radiator is equiped with an oil cooler
Old Oct 4, 2005 | 12:00 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You can hook one hose into the bottom of the block (drain hole), and tee the other into the outlet side of the heater core (the hose that would go to the top of the water pump on a carbed car).
What are you putting this on?
Old Oct 4, 2005 | 12:08 PM
GTA350JAG's Avatar
It is a 87 Corvette motor swap in a 86 Iroc and the vette had the tube go to the water pump so im trying to figure out where to put it. Their is the one that goes to the side of the block then i have the one that runs under the oil pan to go to the water pump but im not using the vette water pump so i need to know where to put it
Old Oct 4, 2005 | 12:14 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Is it comming from the oil filter housing?
Old Oct 4, 2005 | 12:20 PM
GTA350JAG's Avatar
Yes thier are 2... One goes to the side of the block and the other is the one that runs under the oil pan to the other side where it would be hooked up to the water pump (If still in corvette) So now im just trying to figure out where it would go for a camaro
Old Oct 4, 2005 | 12:23 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Take the oil cooler off and you will be fine
Old Oct 4, 2005 | 12:25 PM
GTA350JAG's Avatar
lol i problly will if i cant figure something out
Old Oct 4, 2005 | 12:26 PM
Lo-tec's Avatar
I have the same one, and just tee'd it into a heater hose. If yours has a return hose to the radiator on the pass. side, you can tee it into that one.
Old Oct 4, 2005 | 12:30 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Ok Now I get it. Sorry I was thinking of a differnt style of oil cooler. The kind that ran oil through those lines. Sorry yes you just need to tee into the heater core lines.
Old Oct 4, 2005 | 12:38 PM
GTA350JAG's Avatar
haha ok thanks guys
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Navy8125
Aug 21, 2015 09:32 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
