350 TPI or 383?
Transmission: 4L80E/4L80E
1st, you don't "bore it out" to 383. A 350 becomes a 383 by changing the crank to a 3.75" stroke unit and cleaning up the cylinders with a .030" overbore.
TPI has difficulty handling a healthy 305. Saddling a 383 with it borders on criminal - at the very least, insanity. Unless, of course, you're willing to change out everything factory with aftermarket such as a Stealth Ram.
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
If the bottom end is not going to be rebuilt or in need of one then i would say wait on it. If you need to do an overhaul already then go for it, not a whole lot more expensive then a good overhaul...
Simply looking for more power? That tpi unit is one huge restriction in your 350's power potential, hog that sucker out or look into aftermarket upgrades
Keep in mind however that there is No replacement for displacement...
except boost or nitrous i guess...
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I would do the 383. So what if you loose some power throught the intake. You can always swap that out later. Build for what your going to do down the road.
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Go with a 383. You can get right around 20+hp and tq over a 355. Sure the intake is going to choke the engine but its still going to make more power than what yur running now!
Engine: 350 tpi
If your already doing a rebuild then YES ITS WORTH IT
Theres no replacement for displacement, and every mod you do down the road will make more power becuz of it.
