LT-1 Price?
Old Oct 17, 2005 | 06:39 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
LT-1 Price?
I was wanting to know if 1500 was a bad price for a LT1 and a aout tranny? I think it has around 40000 on it and it is in a 95 Z So you all would tell me if i should buy or let it go on thanks
Old Oct 17, 2005 | 07:18 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
I bought my lt1 and transmission for $2000, but it also came with a custom wiring harness and a bunch of other stuff like exhaust and headers.
Old Oct 17, 2005 | 08:28 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Not too bad, I give 2700 for motor/6-speed, wiring, accessories, PCM, radiator and fan setup.
Hey Chevyowner, you need to come over to the board at Highperformance Toys we have several people from the Tri Cities on it.
Old Oct 18, 2005 | 05:04 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
That sounds like a good price to me if the milage is really 40k. Can the seller verify it? I spent 2300 on an lt1 from a vette with no transmission. it had 60k on it, but it came with all accessories and the computer.
Old Oct 18, 2005 | 05:17 PM
TexasLT1's Avatar
Car: '92 RS
I paid $1500 for an F-Body LT1 with 30k miles, all accesories, harness, and PCM, no transmission. So yeah thats a good price.
Old Oct 18, 2005 | 07:39 PM
Doom Sayer's Avatar
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
Where are you guys buying them at? Any links to sites or you doing it local?
Old Oct 18, 2005 | 08:11 PM
Car: 1992 camaro
Axle/Gears: 3:73
Yea I think the guy selling it can be trusted. And thanks for the link Klortho. And I have found alot of places for the LT1 iI think it was like 2500 with the 6 speed one is www.billyghramscomaro.com
Old Oct 18, 2005 | 09:29 PM
Klortho's Avatar
Car: 1987 GTA
I got mine from Tennessee Auto in Cleveland Tn. He parts out 4th gen cars and usually has at least 1-2 LS1 and 1 LT1 and has good prices.
Old Oct 18, 2005 | 10:38 PM
Firebat's Avatar
buy it. 95 LT1's are my personal favorite.
Old Oct 19, 2005 | 06:07 AM
hotrodln's Avatar
Engine: Lt1 in IROC
I bought my engine from Contemporary coverttes in Bristol PA. These guys have several Lt1"s and LS-1's on hand all the time.
Old Oct 19, 2005 | 10:39 AM
Doom Sayer's Avatar
That link does not work.
Old Oct 19, 2005 | 11:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
www.billygrahamscamaro.com
Old Oct 19, 2005 | 06:11 PM
Car: 1992 camaro
Axle/Gears: 3:73
one more thing did you wire it up your self or have it done? I have read on here how to do it but i'm not good with wires and if you did do it your self how hard was it really??
Old Oct 19, 2005 | 07:07 PM
Klortho's Avatar
Car: 1987 GTA
I did mine myself, just grabbed a multimeter and started tracing wires out. Plus it helped that I had an underhood fusebox from a 4th gen as well which helped a bunch.
Old Oct 19, 2005 | 07:18 PM
hotrodln's Avatar
Engine: Lt1 in IROC
If you really want to make it easy to wire up, try out lt1wiring.com Someone put me on to this guy and he grafted my wire harnesses together.......that made it a plug in affair. The cost was 575 which was less than some standalone wire harnesses. Hope this helps.
Old Oct 19, 2005 | 07:44 PM
Klortho's Avatar
Car: 1987 GTA
True, but 575 will buy a lot of go fast goodies...that's alot to spend on wiring when you only have to hook up around 8 wires.
Old Oct 19, 2005 | 09:08 PM
hotrodln's Avatar
Engine: Lt1 in IROC
yeah I guess so, but time is money too...........I used to have allot more time than I do now........a wife ,two kids, business to run........maybe next time I'll try it just using the book...........I'm sure it's pretty easy after you've done it once or twice..............
Old Oct 20, 2005 | 07:34 PM
Car: 1992 camaro
Axle/Gears: 3:73
Klortho I take you hooked up your own what i was planning on doing. I had one guy was going to do it for 600 but i think it was to much for what little bit I've read you have to do. By the way how far are you from me?
Old Oct 20, 2005 | 09:22 PM
Klortho's Avatar
Car: 1987 GTA
I'm about 30 miles west of Knoxville, around 2 hours or so. I might be able to work something out to head that way. My wife has family that lives in Bristol and could probably take a weekend to come and visit them and maybe help you out as well.
Old Oct 21, 2005 | 09:48 PM
Car: 1992 camaro
Axle/Gears: 3:73
Sure if you dont mind but it will be after the first of the year when i get started.
Old Oct 23, 2005 | 06:03 PM
Car: 1992 camaro
Axle/Gears: 3:73
Also have you guys bought or made a cia for the LT1 in a camaro. If so what parts did you use or a link where i can get a cheap one thanks
Old Oct 23, 2005 | 06:21 PM
hotrodln's Avatar
Engine: Lt1 in IROC
I used my original TPI air filter setup. i used k&N air filters and I sawed off all the baffling. In place of the mass air flow sensor iused a 3" diameter exhuast connector from the parts store. i sprayed it semigloss black . The original TPI bellows works fine on the front of the lt-1 engine.............
Old Oct 23, 2005 | 08:45 PM
Klortho's Avatar
Car: 1987 GTA
I used the LT1 elbow and made a CAI for the one in mine. Swapped the battery from the driver side to the passenger side (since the Firebirds are on that side) and it works like a charm.
88SS6SPEED
Nov 11, 2015 07:05 AM
sreZ28
Oct 22, 2015 08:21 AM
bjpotter
Oct 15, 2015 11:07 AM
okfoz
Sep 22, 2015 03:37 PM
pimprs
Sep 10, 2015 03:34 PM
