will a shim fix this?
Old Oct 23, 2005 | 05:33 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Hey guys,
Im finishing up my 305 carbed to 350 vortec tpi swap. As I went to start her up for the first time I heard nothing but the starter motor. I climbed under the car and had someone turn the key and I see the starter gear come out to turn the flywheel and I noticed the gear is about an inch away from the flywheel. I have a vortec L31 block and the starter that applies to that block but I have the flywheel for an L98. I had to get that starter to match the bolt pattern to the block. If I shim it do you guys think it will help me with my problem or am I gonna have to get a different starter?
Thanks,
Old Oct 23, 2005 | 09:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: will a shim fix this?
Originally posted by vortec77
I have a vortec L31 block and the starter that applies to that block ... I had to get that starter to match the bolt pattern to the block.
I don't understand that part. The block should be drilled to accept the standard L98/LG4/L69/LB9/LO3 starter for a 153-tooth flexplate.
If that isn't the case, you need a 168-tooth flexplate.
Old Oct 24, 2005 | 11:14 AM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Transmission: Turbo 400
Axle/Gears: Moser 9 inch/4.56 gears
I'm with you five7kid----he may not be aware that the starter for the L98 will bolt up. At this point (I'm assuming the motor is in the car since you're trying to start it up) it's easier to replace a starter than the flywheel. Oh, and to answer the question about shimming, No it cannot be shimmed to work. If anything, a shim will move the starter away form the flywheel even more.
boo
Old Oct 24, 2005 | 07:04 PM
vortec77's Avatar
Car: 86 T/A
boo
The bolt pattern for an L31 is an off set pattern where as an L98 bolt pattern is parallel (both bolts right next to each other) I had a couple of guys I work with said I would probably be able to get an after market starter that would match the bolt pattern to the block and also match the L98 fly wheel, but we'll see. (soon i hope) Unless im wrong and an L98 bolt pattern is also an off set pattern?? If I am, Im sure someone here will be nice enough to correct me
Thanks,
Old Oct 24, 2005 | 08:44 PM
five7kid's Avatar
If there are three starter mount bolt holes in the block's starter mount pad, an L98 starter will work.
Old Oct 24, 2005 | 09:39 PM
vortec77's Avatar
Car: 86 T/A
Ill have to take another look, but Im sure there are only two holes. If there are only 2, do you think theres an aftermarket starter i can buy from Summit or jegs or some place else?
Old Oct 25, 2005 | 04:52 AM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
I've had several small blocks and big blocks that had staggered bolt pattern starters and all of them had a third hole that would take an in-line bolt pattern starter. This is just from my experience and it may be coincindental. Let us know if you have a block that will only take a staggered bolt pattern starter (it's good to know these things). From what I understand, a staggered bolt pattern starter will only work on a 168 tooth flywheel (I'm sure someone will let me know if this is incorrect).
If it will take an in-line bolt pattern, you're in luck. As I'm sure you already know, you can get an in-line starter for both the 153 and 168. Hope you don't have to pull the motor just to change the flywheel------that sounds like something that would happen to me.
boo
Old Oct 25, 2005 | 06:35 AM
vortec77's Avatar
Car: 86 T/A
boo
I tried using the 305 starter from my old motor when i first tried to bolt it up and found that it had a staggered bolt pattern and i couldnt use the starter because there was no THIRD hole. So then i got the starter that for the L31, (high torque starter too, really light compared to the L98) would have cost me alot almost 200 bucks if i didnt have a friend that worked at the parts store.
Old Oct 25, 2005 | 11:32 AM
If your block has only 2 holes, then you have no option other than using the 14" flex plate.
The inboard hole of the 2-hole pattern, being farther outboard than the one you need, would go RIGHT DIRECTLY THROUGH THE MIDDLE of a starter drive in the correct place to mate with the 12.8" flex plate. So unless you know of a way to make a bolt with about a 1/2" offset in it (I sure don't, but then I'm sofakingdom, I don't know much of anything anyway except what I can see), there's NO POSSIBLE WAY for a starter to exist, that will work with a 12.8" flex plate and bolt up with the 2-bolt-hole pattern.
Old Oct 25, 2005 | 06:21 PM
vortec77's Avatar
Car: 86 T/A
Well I talked with a technical assistant at summit and he said they have a starter with a staggard bolt pattern that will apply to a 153 tooth flexplate. Thats the good news, the bad news is its $260.00!
Old Oct 25, 2005 | 11:04 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could always drill and tap the block to fit a parallel bolt pattern, like I did.
Old Oct 26, 2005 | 06:20 AM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Ouch!! For $260.00 I would have to take the motor or trans out and change the flywheel. Well at least you have a couple of opitons, although neither one is very easy/good. Good luck.
Old Oct 26, 2005 | 05:30 PM
vortec77's Avatar
Car: 86 T/A
Yeah Thanks
Old Oct 26, 2005 | 05:57 PM
five7kid's Avatar
$260 shouldn't all be charged to "fixing" the issue with the block mount. You're getting a better design starter in the process.
Still seems wierd that the block doesn't have the proper bolt provisions. Are you sure it's a real L31 block?
Old Oct 27, 2005 | 01:08 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Couldn't this problem have been avoided if you had checked the starter on the engine while it was out of the car? That's what I did when I put my motor together to make sure my starter would work with my flexplate. Hindsight is always 20-20 though I suppose.
High-quality ministarters are definitely nice to have though.
Old Oct 27, 2005 | 10:42 AM
I shouldn't have said that the larger flex plate is the "only" option, because there is that one. That's what I have usually done in this situation too. What I should have said was, that getting the right flex plate is the only option as long as there's only 2 holes in the block. And, changing out the flex plate, is not really that hard; you put 2 long (like 6") bolts in 1 of the holes on each side, support the trans with a trans jack or something, take all the other bolts out, slide the trans back, and use a long box wrench to get to the flex plate bolts.
Old Oct 27, 2005 | 04:46 PM
vortec77's Avatar
Car: 86 T/A
Hey Duron your right I should have checked and made sure, But its my first engine im doing pretty much by myself so this will be one of my first mistakes with my first engine swap.You know what they say "experience is the best teacher". Five7kid, I am positive it is an L31 block, I work at a dealership where they pulled the motor out of a 2000 pick up truck, it was a town help truck. Sofaking, I could the flexplate swap but its getting cold outside and the car is outside for now unfortunately. Guess ill just wait to save up some green for the starter. Besides, Just like five7kid said, Im getting a better designed starter anyway
Old Feb 3, 2006 | 07:07 PM
vortec77's Avatar
Car: 86 T/A
Well, Im just updating this thread. Now that the holidays are over i finally got my starter yesterday. Hopefully I get some good weather thrown my way and Ill finally be able to fire this thing up and see what else i have to replace or remove and reinstall, who knows maybe everything will work out ok for once.
Old Feb 4, 2006 | 10:06 AM
ljnowell's Avatar
If you can get the right flexplate, why not just change it, its certainly not something that requires the pulling of the engine.
Old Feb 4, 2006 | 07:23 PM
vortec77's Avatar
Car: 86 T/A
As i said before in another response the car is outside and being that i cant work on it in the cold, i thought i could save up some money to buy a better and stronger starter that would work out. Thanks,
NZKnight
Oct 15, 2015 02:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
