383, AFR heads, TPIS base, siamessed runners...427hp???
Old Oct 23, 2005 | 06:22 PM
Winger4800's Avatar
Car: 2003 Corvette
Transmission: one that has 6 speeds
I read in the TPIS book that 427HP is possible with this setup...does that sound realistic???? I need todo a motor this winter and was wonder what would be the best setup for around $5000ish that would put out a minimun of 400hp
I already have the TPI setup...so just need the motor....will 5K be enough???
Old Oct 23, 2005 | 09:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yeah, gross flywheel on a dyno.
Net, no way.
Rear wheel, not even close.
Old Oct 25, 2005 | 11:51 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
whats the diff between gross and net??
Old Oct 25, 2005 | 01:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Gross - Open headers, no accessories, no water pump, no air cleaner.
Net - All accessories, water pump, air cleaner, full (muffled) exhaust system.
Old Oct 25, 2005 | 01:44 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Old Oct 25, 2005 | 06:24 PM
Air_Adam's Avatar
Originally posted by CamarosRUS
evilstuie
Jan 9, 2020 08:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Aug 12, 2015 07:08 PM
Sanjay
Aug 12, 2015 03:41 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
