Which SFC's with Hooker 2226 headers?
Old Oct 25, 2005 | 08:12 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I have CE weld in sfc's on my car now but the Hooker 2226 BBC swap headers dump right where they are. Is there another sfc that would work better with them.
Old Oct 26, 2005 | 03:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
How set are you on the headers? Have you seen this thread? https://www.thirdgen.org/techbb2/sho...11#post2594711
If the 396 ever ends up in the Camaro, that's the route I'd take.
Old Oct 26, 2005 | 07:07 PM
Blackroc86's Avatar
Car: 1986 Iroc
I already have the headers in the car. I had to trim about 6 inches of the front of each sfc to get them bolted up. Maybe this winter I will try to make some that leave room behind the collector to run some mufflers for a little street use.
Old Oct 26, 2005 | 07:13 PM
five7kid's Avatar
From the BBC Swap threads, it appears some trimming/modification is required regardless. I'm not sure how the Spohn SFCs would line up with those collectors, but from what little I know of the headers, and knowing what the Spohn's look like, I wouldn't think they'd get in each other's way.
Modification/fabrication is probably your best bet, anyway.
redformula88
Oct 14, 2015 06:08 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
hdis2002
Sep 8, 2015 02:52 PM
