grades of steel
Old Nov 7, 2005 | 08:50 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
grades of steel
is a 4130 "forged steel" crankshaft a stong piece? i dont know much about gradeing of metals and was just wondering if it were strong, i found a brand new crank for 300 bucks just wondering if it was worth it or not? thanks
Old Nov 7, 2005 | 09:27 PM
TexasLT1's Avatar
Car: '92 RS
4130 is lower grade steel than 4340 and is weaker. I'll give you the descriptions of the two alloys in my metals catalog and let you decide.
4130 - General puprose allow. Low in cost with a nominal .3% carbon, .95% chromium, and 20% molybdenum. Offers good strength and toughness for mederately stressed parts.
4340 - highly alloyed steel, nominally 1.80% nickel, .80% chromium, .25% molybdenum - assuring deep hardness when oil quenched, with high strength characteristics attained throughout the section. Used for heavily stressed parts operating under heavy-duty conditions.
In other words, if you can, get the 4340 forged crank. I don't know how the 4130 compares to a cast crank but I would doubt there is a whole lot of strength difference.
Old Nov 8, 2005 | 12:41 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You could try a 5140 crank. They are stonger then a 4130 but cheaper then a good cro-moly 4340.
3rdgenparts
May 21, 2016 11:50 PM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
Tarizza
Sep 24, 2015 12:57 PM
ban1one
Aftermarket Vendor Review
Sep 15, 2015 10:10 PM
