396 BBC Swap Questions on 90 Camaro Street car
Old Jan 30, 2007 | 09:37 PM
  #101
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
That makes sence but my dad has a 1960 origional top fuel slingshot. Dosent have the motor or anything but they were solid mount motors. With a solid mount nitromethane sbc i think it would rattle and shake alot more than a cage in a mild street car. The chassie is fine with no cracks in any of the welds.
Old Feb 1, 2007 | 01:16 PM
  #102
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'm just telling you what the owner or PA Racing told me.
Old Aug 22, 2007 | 01:25 PM
  #103
87z28ss's Avatar
Re: 396 BBC Swap Questions on 90 Camaro Street car
Originally Posted by greezemonkey
here`s my street strip BBC Z28..if you need any advice on the swap let me know.
http://www.cardomain.com/ride/487725
Hello . im also in NJ (and NC) . I have a 87z28 that i want to put a 454 in . my question is : how impossible is it to get someone to put and inspection stick on it ?? ha . seriously can u get it inspected or do you just have to know someone ??
Old Feb 21, 2008 | 10:16 PM
  #104
killerkev's Avatar
Car: 92 formula
Engine: 350 tpi
Transmission: damn 700r4
Re: New Update:
why couldnt we put the fans on the front of the rad and let them blow thru the rad for clearance????
Old Feb 22, 2008 | 05:55 AM
  #105
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Originally Posted by maxrochatansky
got another question for our boy greezemonkey. you should all check out his BBC camaro : 1985 Chevrolet Camaro - scott's Chevrolet "'THE MACHINE'" . I noticed that you have installed a tubular k-member to shed some weight. I am thinking in that direction, too. (installing a 454 as well) There has been some controversy about tubular k-members, that they supposedly wouldn't to able to handle the stresses placed on by daily driving (potholes , etc...) Are you using it as a daily driver , and have you noticed any problems ??? Thanks for your input. BTW that company you got them from , profabracing really appears to be out of business. (?) Anyone heard of those guys lately ? cheerzz
I daliy drove it for 3 yrs...well at least as daliy as a hobby car gets driven. The Kmembers are fine to drive, the a arms are the only thing Ive seen fail...and I have only seen pictures of 1 at that. Profab is out....there are many others out there now with the latest and greatest, when I did mine there was not a lot of guys using them.
Old Apr 9, 2008 | 06:28 AM
  #106
sngreen's Avatar
Car: 1984 Z28
Engine: 468 Ci
Transmission: T-5 (Until it breaks)
Axle/Gears: 3.73 posi
I am planing to do the BBC swap in my 84, I am going to use the t-5 for now as i dont have enough to buy a t-56 or a richmond, has any one use one in there swap before, what kind of flywheel should i use, and will those headers clear the slave cylinder. Thanks for any and all help!!!!
steve
Old Nov 11, 2008 | 02:47 PM
  #107
JCheves's Avatar
Well i have been reading this post for the last 6 months I finally got the bugs out of this old 427 it's going in a 89 camaro. I wanted to thank all the people that put this info on this post. It helps alot if before you even start to know what is going to happen.
Attached Thumbnails 396 BBC Swap Questions on 90 Camaro Street car-100_189555.jpg
Old Jan 10, 2009 | 01:52 AM
  #108
freeway's Avatar
Car: 1984 Camaro
Engine: 1969 BBC 427
Transmission: TKO 600
Axle/Gears: Currier 3.75
Blackroc86,
Good Day,
I have an 84 camaro and I am currently undergoing the bbc conversion. Do you have any saved notes and pics of your engine swap? Thank you, your efforts are greatly appreciated.
Greezemonkey
Good Day,
I am currently installing a bbc 427 into my Camaro, I have the k-member, long tube hooker headers. I have read your post several times and it has helped alot. Did you incounter any problems with the long tube headers and the k-member; the headers clearing the k-member... the headers clearing the floor pan etc.....
Old Jan 10, 2009 | 03:38 PM
  #109
killerkev's Avatar
Car: 92 formula
Engine: 350 tpi
Originally Posted by freeway
Blackroc86,
Good Day,
Greezemonkey
Good Day,
a-i am still gathering info and pieces needed. finally decided to put a 8.8 ford rearend conversion.found a f-150 rearend(too wide) but it had a limited slip and the 3.55 gears i wanted. a explorer housing is the perfect width-am saving for moser axles, c clip eliminators,and having the brackets cut off the gm rearend&welded on the 8.8-the lil gm rearendwont last 2 burnouts with the 496 thats goin on this 82-hope this helps-the header thing about drove me crazy- if you put anything with a primary tube smaller than 2 on a big block youo are killing your power. ed quay makes excelent headers that actually fit.`the hookers are a joke-and the patriot clipsters are not tuned and just too small . i am trying to do this right the first time-i dont want to have ot go back and strenghten things once i get it done, and i dont want to give up any horsepower, just to be a little easier--i want to go kick some *** with this beast!!! if i can help at all dont hesitate to drop me a line
Old Jan 14, 2009 | 01:23 PM
  #110
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Found this thread VERY useful. I know everyone has their sticky threads and such, but thanks for all the useful information.
Old Apr 4, 2009 | 12:18 PM
  #111
69RS350's Avatar
Car: 89RS,69RS
Engine: BBC 396
You will have to check your state laws. I know when I was in Alaska you could install any motor that was an option when the vehicle was ordered. The motor also had to be the same year of the vehicle or newer.
Old Jun 16, 2009 | 02:09 PM
  #112
GSRMmi31's Avatar
Car: 92 RS
Engine: 2000 454 Carb
Have you got any pictures, i am also doing the swap from a 350 to a 454.
Old Aug 17, 2009 | 12:49 PM
  #113
mongo136's Avatar
Car: 89 camaro rs
Engine: 468 bbc
Transmission: powerglide
Axle/Gears: 373 S-60
I am somewhat new here, but i am in the process of fitting my 468 bbc into my 89 rs. it is merely for fitment and then will be removed for paint, and put back in. A lot of work I know, but i want it to be nice. I will try to put up a pic to show the first fitment. I got the hookers on ebay ceramic coated for 350$ i believe they are waayyy more than that new, but these were in like new condition, althought there was quite a few fitment dings in them. The car currently has the stock mounts in it, but it will be changed to a tub k-member, hopefully adding some realestate and saving a few pounds. the car will be street legal (barely) 468 bbc 13:1 powerglide-4500 stahl with a brake.
Attached Thumbnails 396 BBC Swap Questions on 90 Camaro Street car-img00031.jpg
Old Aug 17, 2009 | 05:26 PM
  #114
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Good luck with your project. Here's a link to mine.
https://www.thirdgen.org/forums/engi...ml#post4255410
Old Dec 2, 2009 | 10:37 AM
  #115
GSRMmi31's Avatar
Car: 92 RS
Did you have to cut or modify anything in order to fit the hookers.
Old Dec 2, 2009 | 01:14 PM
  #116
GSRMmi31's Avatar
Car: 92 RS
Re: New Update:
Did you ever get a answer for this, i am curious cause i will be using a ling water pump and will have plenty of clearance problems. Please let me know. Thanks
Old Dec 3, 2009 | 10:28 AM
  #117
Car: 1992 Camaro RS
Transmission: WC T5
Re: New Update:
I just ordered the hookers yesterday. I'll post all the work on my thread linked above. Should have em on next weekend.
Old Aug 11, 2014 | 03:55 PM
  #118
OConnorRacing's Avatar
Car: Harley
Transmission: tb 350
Axle/Gears: no idea
Hey I have a few questions on making a BBC swap in a 88 camaro, I have the 427 and turbo 400 trans, What rear would work best, and what rear is the cheapest to run ? would a 4th gen rear work past the first run.
John
Old Aug 11, 2014 | 04:45 PM
  #119
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
John
You shouldn't be compromising the integrity of other people at the track because you want to run it on the cheap.. If you want to race the car, you need to do it properly and cover the safety aspects first. AKA: it's time to step up to a 9" or equivalent. You give it one good rip and that 7.5" is going to blow apart like a hand grenade if it hooks.
Next time just make your own thread considering this one is OLD (dating back to 2005, actually).
Old Aug 12, 2014 | 03:18 AM
  #120
Car: Harley
Axle/Gears: no idea
WOW can you be any more of a condescending loser, there is a way to explain things it must be a part you are missing
theshackle
Mar 5, 2017 06:37 PM
reiderz iroc
Aug 13, 2015 04:57 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
z28addict8490
Aug 7, 2015 08:48 PM
