3rd gen serpentine on early SBC
Old Nov 14, 2005 | 02:27 PM
1st3rdgen23's Avatar
Car: 1990 RS
Engine: 305 tbi (currently)
Transmission: B/W 5spd
i'm wanting to swap out my 305 tbi in my 90 RS for a warmed up 350 w/ Vortec heads but, i still want to use the 'maro's serpentine belt set-up. can i run a reverse rotation water pump on my early block and Vortec heads?
Old Nov 14, 2005 | 03:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sure can!
Old Nov 14, 2005 | 06:06 PM
Car: 1990 RS
will i have any cooling problems? and why do the LT-1 heads have to be modified to run on an early-style block? aren't they reverse flow heads?
Old Nov 14, 2005 | 06:39 PM
five7kid's Avatar
Your current water pump is reverse rotation, but the engine flow is the standard Gen I radiator-pump-block-heads-radiator.
LT1 is reverse flow, meaning the flow goes radiator-pump-heads-block-radiator. There are passage differences between the Gen I blocks & heads and Gen II blocks and heads.
Vortec engines/heads are Gen I style.
Old Nov 15, 2005 | 08:27 AM
Car: 1990 RS
thanks for the info, you've been a great help!
Old Nov 15, 2005 | 01:44 PM
Blkmaroman's Avatar
Car: 1998 zx9r
Engine: 899CC inline 4
Transmission: 6 speed manual
Axle/Gears: 15T front sprocket, 43T rear
The problem i ran into when putting serpentine on my 86 iroc was the alternator. MY car had the old two wire plug and the only alternator that would go on the serpentine setup was one that needed the newer bigger plug with more wires so i didnt put on the setup. Hopefully there might be an easy way to get around this so i can get the v belt crap off my car.
evilstuie
Jan 9, 2020 08:29 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
mustangdmurder
Aug 21, 2015 07:17 PM
bjpotter
Aug 12, 2015 06:06 PM
