Hood clearance with new motor.
Old Nov 15, 2005 | 11:47 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I just dropped in a new 385 with a Victor Jr. intake on top. Is there anyway that this thing is going to fit under a stock camaro hood? I can cut the inner fram off the hood too for more clearance. I also want to add a 3/4" N20 plate. I have moched it all up and it looks WAY to high for a stock hood, but maybe the angle of the car with no hood, or fenders is throwing me off.
Thanks.
Old Nov 15, 2005 | 09:09 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I can't see any way your gonna fit it under the stock hood.Maybe with no air cleaner,but even then your carb will be sucking straight from the bottom side of the hood.A 2 1/4or2 1/2 " cowl or something along those lines should get you the clearence you need.
Old Nov 16, 2005 | 06:46 AM
Engine: LS3
yeah thats what i thought. Damn. I love my stock mint hood. Oh well. 3"Cervini it is I think. Harwood seems to have fitment issues.
Old Nov 16, 2005 | 08:32 PM
Irockz's Avatar
My Harwood fits great,but it's the only one I've ever dealt with,mine may be one good one in a million.
Old Nov 16, 2005 | 09:37 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
Vic Jr. w/ Demon carb, drop base aircleaner will fit.. running any kind of spacer under the carb will not fit
Cervini I have a 4" Harwood Outlaw hood, i coudlnt cram my Vic Jr. 2" spacer, demon carb and fogger system all underneath Fits ok but needed alittle work, nothign out of the ordinary for an aftermarket fiberglass hood tho
Old Nov 17, 2005 | 01:28 AM
EvilCartman's Avatar
Car: '82 Z28
I was able to fit a vic jr, 1/2 inch spacer, demon carb and drop base aircleaner under the stock hood of my car. Added a N2O plate and needed a cowl hood for everything to fit The hood is the factory composite hood though, no bracing to speak of but the fake vents do pop down a ways.
Old Nov 17, 2005 | 06:50 AM
Engine: LS3
Thanks for the replies guys. I will cut all the bracing away neer the motor. I have a Vic Jr.** 3/4" N20 plate**750 DP Holly**I have no air filter yet, It miiiiight sqeeze in. I guess just wish me luck, haha. Hood won't be going on anytime soon anyways.
Old Nov 27, 2005 | 05:06 PM
zcamaro28's Avatar
Car: 1984 camaro z28 / 1994 jeep wrangler
Engine: 383 stroker / 4.0 HO straight 6
Transmission: built 700r4 / 5 speed
hey guys im running a vic jr and i was wondering whats the smallest cowl i can go with i have an edelbrock elite aircleaner
Old Nov 27, 2005 | 07:13 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Is that the foam triangle filter? if it is, do yourself a favor and get rid of it before it drops a bunch of crap in your engine. I normally dont just jump in someone's thread and give my .02 but in an instance like this I will.
Old Nov 28, 2005 | 07:28 AM
Engine: LS3
I am getting a 3" cowl from champion fibergalss. There is NO way my hood will fit with my N20 Plate. I would also recomend a normal style filter.
Old Nov 28, 2005 | 10:34 PM
zcamaro28's Avatar
nah its the paper element one.
Old Dec 10, 2005 | 01:06 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Got my Cervini
I hope it clears my edelbrock rpm vortec air gap.
Old Dec 10, 2005 | 09:41 PM
ukgobigblueuk's Avatar
Champion Fiberglass Products
Several of my friends and I drove up to there shop and put the hoods on in there driveway. We all left very happy and with $ still in our pockets. They are not quite as nice as Cervinis but they are over $200.00 less!! Chec them out at www.championfiberglassproducts.com
Good luck with your choice.
Old Dec 11, 2005 | 11:12 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Look in this thread
https://www.thirdgen.org/techbb2/sho...&highlight=L88
As long as you don't have the tall Vic Jr.
It will fit with the right drop base air cleaner. In the thread.
may have to switch the NOS plate for a 1/2" plate thou.
Or drill and install the NOS tubes right in the intake manifold plenum.
Removal of the choke air horn on a holley carb is required.
Uses a 14-3" element and does not restrict air flow once the choke horn has been removed..
All in all less $$$ than a cowl hood.
Hotrodboba400
Dec 10, 2019 07:07 PM
hartsmike
Oct 4, 2015 01:00 PM
customblackbird
Oct 1, 2015 04:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
