383 will it fit?no prooblemo??
Old Nov 20, 2005 | 05:43 PM
demetri's Avatar
Sorry if I'm posting this. I used the but I couldn't find it. I have a 91 Camaro RS. I wanna know if a ZZ383 crate will fit in my car with no fabrication just slip in.
Old Nov 20, 2005 | 05:50 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
it will bolt right up to your trans, so yes it will fit.
Old Nov 20, 2005 | 05:53 PM
demetri's Avatar
Not to a T-5.....what would you recommend for a manual tranny?
im happy that i can have a 383 in my camaro without fabrication
Old Nov 20, 2005 | 07:10 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
It will bolt up to your t5 but you will need a different flywheel. You could go t56 but that gets spendy. I know I just got mine done.
Old Nov 20, 2005 | 07:11 PM
demetri's Avatar
So you just slipped it in with some new headers , tranny, and all accesories, and thats that? how long that take you
Old Nov 20, 2005 | 07:22 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
ah a while. actully its still not done.
Old Nov 20, 2005 | 08:27 PM
demetri's Avatar
Where would you get a T56??? junkyard? im guessing new would be 2000$
Old Nov 21, 2005 | 12:11 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Keep an eye on the parts for sale. One usally pops up every couple of weeks. And there is always ebay. This is how much my t56 swap cost.
T56 w/bellhousing - $800.00 (TGO board) used
Flywheel - $350.00 (Jegs) new
Clutch - $250.00 (Jegs) new
Hydrolics - $150.00 (ebay) new
Stock shifter - $40.00 (ls1tech.com) used
Aluminum spacer for the slave cylinder - $50.00 (Hawks) new
Crossmember - $100.00 (Spohn) new
Peddle assembally - $40.00 (TGO board) used
Miss. Bolts ect. - $15.00 new
Total - $1795.00
Now you could maybe do it cheaper. The spacer and shifter didnt come with the trans. You may get one that has thiese parts. But I think that is a good estimate on the swap.
Old Nov 21, 2005 | 05:09 AM
demetri's Avatar
Thanks, Im guessing a T56 can handle 500ftlbs of torque. But if i get that ZZ383, than the tranny would be almost at its limit wouldnt it?
Old Nov 21, 2005 | 08:31 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Well the limit depends on how you drive it. I have a buddy who is putting down 425 hp to the wheels through a stock t56 and its even a 93 trans. (93 had weeker trans. If your going to get one look for a 94-97 trans.
Old Nov 21, 2005 | 02:49 PM
demetri's Avatar
thanks man, youve been very helpful. Just a few more things. Can my existing power steering pump, a/c pump and alternator on my 305 can be transfered to a zz383??? aswell as intake manifold and throttle body?
Old Nov 21, 2005 | 02:55 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Yes all accesories will bolt up. As for the TBI. I would think about ditching it. If you can go with a mpi system do that. Otherwise I would think about switching to carb. But my vote would be for fuel injection
Old Nov 21, 2005 | 02:56 PM
demetri's Avatar
would you happen to have MSN or AIM?
Old Nov 21, 2005 | 04:06 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
my aim is grover1233.
Old Nov 21, 2005 | 05:31 PM
demetri's Avatar
ok im PBracer14. you should be getting a message soon
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
New2Chevy
Sep 28, 2015 12:35 AM
Gambit TA
Sep 1, 2015 07:27 PM
gixxer92
Sep 1, 2015 04:32 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
