What Engine?
Old Nov 28, 2005 | 10:04 AM
19kilo's Avatar
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
What Engine?
I have a 1985 Z-28 LG4 i want to drop a new engine but witch one from that page would be my best bet? That would fit and would it use the CPU wireing harnes or what?I have no idea about any if this stuff i dont want to buy a 1,700 Engine then have to spend alot more to change stuff to get it to run.
http://www.chevy350engines.com/?gcli...FT8lGgodYwyvMQ
Old Nov 28, 2005 | 10:27 AM
19kilo's Avatar
this?
http://www.morethanjustpower.com/category.asp?id=1
What about this one?
Old Nov 28, 2005 | 01:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Go for the 290 horse crate engine from GM if you get the baseline-type 350.
You're proposing pretty much what I did myself this past summer, except I didn't buy a new engine. The problem I have with these new crate engines that are available is they all have either poor heads, or heads that aren't compatible with your current induction system (speaking of the 350 HO in particular).
Now, if you go to their rebuilt button, you'll see an '88 350 for $1395 +$195 core. That would be an engine worth considering, with the only "issues" to get past being a slight modification to your intake manifold to get the center two mount bolts on each side to fit (or get an aftermarket q-jet manifold for '87-up), and needing a new $35 one-piece rear main seal type flexplate. These guys http://www.rebuilt-auto-engines.com/...28105415126.b9 or http://www.rebuilt-auto-engines.com/...28105415126.b9 have basically the same thing.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
